Hello Guest it is October 21, 2026, 03:30:24 AM
Author Topic: Mach1 to Mach3. Can I use my Mach1 settings for Mach3?  (Read 11782 times)
adsala
« on: July 18, 2006, 11:57:03 PM »
I just upgraded to Mach3.  Do I have to reconfigure everything?  Are there any config files I can use from my Mach1 installation for Mach3 to retain all my settings.   I guess I could bring up Mach1 and write down all the settings then type them into Mach3.  Is there an easier way?
Re: Mach1 to Mach3. Can I use my Mach1 settings for Mach3?
« Reply #1 on: July 19, 2006, 01:23:57 AM »
Dont think you can do that so you will need to do like you suggest and write everything down and set up Mach3. Once you have that done however you can then copy the .XML file for that profile and save it in a different folder as a backup just in case things go wrong later.
adsala
« Reply #2 on: July 19, 2006, 01:52:23 AM »
Thanks.  I saw xml files and kinda knew that the different versions were incompatible..
