Hello Guest it is November 19, 2026, 05:14:33 PM
Author Topic: Feedrate compensation during circular interpolations.  (Read 9177 times)
« on: January 07, 2009, 11:41:32 PM »
Does Mach3 compensate the feed rate during circular interpolations for different diameter tools, or is the feed rate calculated using the center of the tool?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Feedrate compensation during circular interpolations.
« Reply #1 on: January 08, 2009, 04:18:27 PM »
Mach3 feeds at the rate set by the last F command. This is active until changed by another F command.
Graham
