Hello Guest it is November 29, 2026, 02:11:57 AM
Author Topic: Dwell question  (Read 38821 times)
cosmynnec
Dwell question
« on: July 17, 2006, 11:30:15 AM »
Hello, how can i trigger an output when the dwell command is active ? Thanks
« Last Edit: July 17, 2006, 12:10:53 PM by cosmynnec »
Re: Dwell question
« Reply #1 on: July 17, 2006, 05:07:51 PM »
I guess you could use a macro to do this. Set a macro to run on your gcode then on your macro, you could put something like this (im not too familiar with VB programing so I will put it just with normal words)
Activate output
DWELL
DeActivate output
Im sure Brian would actually know the syntax for it
Hope that would get you started though
Re: Dwell question
« Reply #2 on: July 17, 2006, 06:16:48 PM »
You will need to put it in a macropump...
It will look like this:
If GetLED(13) Then
ActivateSignal(OUTPUT1)
else
DeActivateSignal(OUTPUT1)
End if
www.newfangledsolutions.com
www.machsupport.com
Re: Dwell question
« Reply #3 on: July 17, 2006, 06:19:09 PM »
You can easily tell who is the expert!
Re: Dwell question
« Reply #4 on: July 17, 2006, 06:20:49 PM »
 ;D
www.machsupport.com
Re: Dwell question
« Reply #5 on: July 18, 2009, 02:21:31 PM »
Hey guys.
How can I change the dwell setting, mine is dwelling far too long and I am working with plastic so that is a big problem.
I found the G4 dwell setting in General Config but it is just a check box for ms...not a value?
It is currently unchecked...
Any help is appreciated, thanks.
Re: Dwell question
« Reply #6 on: July 18, 2009, 02:52:50 PM »
Dwell time is instructed via code. If you have it set to milliseconds then G4P1 will be 1 millisecond, if set to seconds then it will be 1 second.
 Spindle Dwell can be set on General Config page.
Re: Dwell question
« Reply #7 on: July 18, 2009, 04:08:22 PM »
As I said above the general config page only shows a check box not a value (ms ON/OFF), what am I missing here?
If it is set in the code wouldn't that be in the CAM program then?
Thanks.
Re: Dwell question
« Reply #8 on: July 18, 2009, 04:11:57 PM »
My apologies, spindle dwell is set from Config menu, Ports and Pins, Spindle Setup.
When are you getting the dwell?
Re: Dwell question
« Reply #9 on: July 18, 2009, 04:34:57 PM »
Forgive my novice ignorance but I am not sue what you mean by "where" ?
The dwell occurs anytime the spindle changes trajectory even on SINGLE lines, curves for example..
(only straight lines are ok)
Is that he info you were looking for?
