Hello Guest it is October 28, 2026, 09:22:55 AM
Author Topic: re brains timers  (Read 26653 times)
re brains timers
« on: January 05, 2009, 09:56:49 PM »
Hi everyone ! i am starting into unknown territory here i need to get a warning buzzer to go off for say 1 to 2 seconds and delay the spindle start for same .I looked at the video the first one and could not get the advanced one to run . And i read the pdf file but the timers were not covered anyone that can lend a hand?
Re: re brains timers
« Reply #1 on: January 05, 2009, 10:05:45 PM »
How do you want the buzzer to be turned on? When you turn the spindle on, you want a buzzer for 2 seconds then spindle starts?
« Reply #2 on: January 06, 2009, 08:13:33 PM »
Yes that's exactly what i am looking for : if what i saw in the video is true you can control relays with brains and outputs now as to how the timers work I'm not sure or if what i am asking is possible if it is could you please provide a example with a little explanation on how to do it .I am installing a stack light warning system as this machine is a large mill sets next to a entrance to a building I've scared few folks with this machine starting up and would like to provide a little warning as well as a little safety. Your help would be greatly appreciated thank you
« Reply #3 on: January 06, 2009, 09:22:46 PM »
woffler, what your wanting to do will require a little more than a brain I believe. I have sent you a personal message.
« Reply #4 on: January 07, 2009, 06:36:15 PM »
Woffler,
   Goto ports/pins >spindle, and set your spin CW delay to 2 seconds, in your M3 macro, have a user led like 2000, turn on, have a Brain watch that LED, when it turns on gothrough a timer with a 2 second ON single shot pulse. That will do your Stack Light Buzzer. In your M5 put the User Off for LED 2000 to reset it for the next tool.
scott
« Reply #5 on: January 07, 2009, 06:38:55 PM »
Hey Woffler/Brett,
This little block seems to do what you are describing.
Just put this in the M3 macro.
Is it SAFE ?
ActivateSignal(Output3)      'OUTPUT of choice for BUZZER
Code "G4 P2"                    'BUZZING for duration of "P" (sec.)
While IsMoving
Wend
DoSpinCW()                      'SPINDLE START
DeActivateSignal(Output3)  'BUZZER OFF
Just tinkering,
RC
« Reply #6 on: January 07, 2009, 08:21:22 PM »
Hey Poppa...good timing !
Just tried your method for the practice and experience.....I like it.
Can you tell me if there are any advantages or disadvantages of using either your method or the one I posted ?
Just wondering if I may have overlooked anything that could come back and bite me in the behind.
RC
« Reply #7 on: January 07, 2009, 10:02:57 PM »
Thanks fellows, I'm busy as a one legged man in a butt kicking contest.
« Reply #8 on: January 08, 2009, 04:41:41 PM »
The are many, many ways to do things in Mach, and that is what makes it great for all of us. You way is just as good as mine. I only put mine up cause he asked how to do it with a Brian............
Scott
« Reply #9 on: January 08, 2009, 05:16:05 PM »
That's what I assumed. I tried to do it w/a Brain but couldn't figure it out. You make it seem so simple.......like you spit that out without even thinking about it. A gift I guess.
Thanks Pop,
RC
