Hello Guest it is November 13, 2026, 11:39:52 AM
Author Topic: Mill spindle safety switch  (Read 15994 times)
« on: January 04, 2009, 10:07:57 AM »
Hi
I am making a new spindle with a Dandrea quick change system for my Wabeco CC-F1410 LF high speed spindle mill.
At the same time I will fit a manual spindle lock . The problem I have is finding some way to stop the spindle from switching on when the lock is in place.
I need to know where to wire the micro switch which will be fitted to the lock pin so the spindle will not be able to power up either in cnc or manual mode.
Maybe disable the cnc mode altogether.
Re: Mill spindle safety switch
« Reply #1 on: January 04, 2009, 12:28:43 PM »
I dont know how your mill is wired at the moment but to me a spindle  motor should be powered through contactors, there should be an eStop string that can disable the contactors so that nothing can operate the spindle if the eStop is hit. For your microswitch I would have this also in the line so that if the microswitch is open then the contactors cant operate. To do this would depend on how you have things wired but the way I would do it is on the operating circuit for the contactors I would have one relay for the eStop string and another for the microswitch string. These relays if opened would stop the contacters from closing and thus prevent your motor from operating but as each circuit is seperate the microswitch operating would not interfere with the E-Stop.
Hope this makes sense, it does in my head but sometimes my head is not a place others can see clearly in :D
« Reply #2 on: January 04, 2009, 02:49:00 PM »
Or see through.   ;D
Ed
Ed VanEss
« Reply #3 on: January 04, 2009, 04:05:20 PM »
Or see through.   ;D
Ed
Well thats usually quite easy to do if you get the alignment of my  ears just right ;D
« Reply #4 on: January 04, 2009, 09:10:28 PM »
Hood,
Seems to me,   that's' where the all the  Mach help files are located.  :D
Happy New Year.
Ed.
Ed VanEss
