Hello Guest it is November 19, 2026, 04:32:29 AM
Author Topic: G31 again  (Read 19651 times)
G31 again
« on: July 15, 2006, 02:53:02 PM »
I have trouble using G31. I am new to all this.
When I type into the MDI screen G31 Z0-.1, nothing happens.
I tried the probe wizard ( the one by Art) and the program runs except that at the G31 lines almost nothing happens, the program just goes to the next line of g-code most of the time. On the occasional G31 instruction it seems that the Z backlash is taken up. This happens even when probe depths of .1" are input.
I have verified in the Diagnostics screen that the probe is seen by the program ( the LED blinks when I trip the probe with my hand)
This happens with the probe active high and active low
Version 1.84.001 and 1.90.053
Am I missing something?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: G31 again
« Reply #1 on: July 15, 2006, 03:23:20 PM »
try this in MDI dro
place the probe just above the work
Type :-
G91 G31 Z-1. F10.
Re: G31 again
« Reply #2 on: July 15, 2006, 04:06:45 PM »
I tried in MDI field as well as a g-code program.
No effect in 1.84.001 and 1.90.053
( actually the first time I got a "micro-move " in the Z axis. All subsequent attempts had absolutely no effect)
Is it possible that this is limited in the Demo version?
« Last Edit: July 15, 2006, 04:32:31 PM by looker1 »
Re: G31 again
« Reply #3 on: July 16, 2006, 09:52:56 AM »
Try to put in a debounce of 1000. You may be reading noise...
www.newfangledsolutions.com
www.machsupport.com
Re: G31 again
« Reply #4 on: July 16, 2006, 06:52:56 PM »
Debounce of 2000 seems to work for 95% of the probe cycles...now to debug the other problems, thanks
