Hello Guest it is November 01, 2026, 10:06:04 AM
Author Topic: New problem  (Read 11924 times)
Offline Psad
  •  82 82
New problem
« on: July 15, 2006, 10:40:54 AM »
Attached is my .Tap file (very simple) Gcode cause it to cut inside instead of outside.  What am i doing wrong.
Re: New problem
« Reply #1 on: July 15, 2006, 11:49:05 AM »
will it work if you change the G41 to a 42?
www.newfangledsolutions.com
www.machsupport.com
Re: New problem
« Reply #2 on: July 16, 2006, 03:52:57 AM »
I have a similar problem but only on the outside chain. See attached example (I've tested an other part but the result is the same)
Jean-Louis
Jean-Louis
Re: New problem
« Reply #3 on: July 16, 2006, 09:54:40 AM »
I think there is a problem with the Comp (G42 or G41) that is getting called :( This is not a simple problem and will take some time to fix.
Thank you
Brian
www.machsupport.com
