Hello Guest it is November 01, 2026, 10:05:50 AM
Author Topic: Reverse import of hole into LZ  (Read 10679 times)
Offline Psad
  •  82 82
« on: July 15, 2006, 10:22:43 AM »
I tried loading in an old .tap  from Mach3 to make soe changes (much smaller task) the reverse load into LZ did not bing the Drill points bakc in and they are lost. Can you check this out.
Re: Reverse import of hole into LZ
« Reply #1 on: July 15, 2006, 11:47:29 AM »
That is some code that Art did... I will have him look at it when he gets back on two weeks :)
Thank you
Brian
www.newfangledsolutions.com
www.machsupport.com
