Hello Guest it is November 13, 2026, 11:52:02 AM
Author Topic: Limiting rapid rates in mach 3?  (Read 17892 times)
Offline Zaae
  •  120 120
« on: December 30, 2008, 05:15:19 PM »
Hello again all,
I'm wondering if there's a way to force mach 3 to never exceed the settings in the motor tuning menu.
Right now, if I set my feedrate slider above or below 100%, the rapids change speed too, which I don't want.
Reason is, if I'm cutting a design on hard material, I sometimes pull the feed rate down a bit, which also slows the rapids. Of course, it does it the other way too, if I'm working in very soft material, I crank up the feed rate sometimes up to 200%, and the rapids run extremely fast.
Is there a way to do this?
Thanks!
Z
Re: Limiting rapid rates in mach 3?
« Reply #1 on: December 30, 2008, 05:21:59 PM »
If your rapids are exceeded with a FRO then you must be using an old version as it has been fixed for quite a while.
« Reply #2 on: December 30, 2008, 05:37:07 PM »
If it's NOT an old version, perhaps the Feed and Rapids are Locked in config. and should be un-locked.
RC
« Reply #3 on: December 30, 2008, 05:39:38 PM »
RC
 Nope the locked RRO/FRO should still obey the motor tuning, certainly did when I was testing for Brian after he sorted it.
Offline Zaae
  •  120 120
« Reply #4 on: December 30, 2008, 05:56:13 PM »
Very possible it's an old version, I'll update it asap. Thanks again :)
