Hello Guest it is November 13, 2026, 01:04:38 PM
Author Topic: Wireless network causes steppers to stall  (Read 30133 times)
« on: December 30, 2008, 04:04:08 PM »
Just thought I would pass this along. I've been chasing a stubborn problem with the steppers stalling for no apparent reason. Finally I serendipitously discovered that it was the wireless network adapted causing the trouble. Plug it in .  steppers stall, unplug it, all is well.
Just another thing to add to the troubleshooting pool.
Re: Wireless network causes steppers to stall
« Reply #1 on: December 30, 2008, 04:32:53 PM »
Brett had a problem with his wireless network as well, mine works fine, suppose its like the onboard graphics thing and laptop thing, some work some dont :(
« Reply #2 on: December 30, 2008, 05:02:22 PM »
I have stayed away from anything else running in the background as it only robs the resources from Mach 3 which is a recource hog to begin with.
I've heard the smoothstepper eases this a great deal but if you're using parallel port, it's russian roulette in my eyes -  8)
« Reply #3 on: December 31, 2008, 08:33:12 AM »
I'm fairly certain that the problem is the radio waves emitted from the wireless adapter and not the CPU drain.
I'm now running a dual processor machine and I have biased one processor completely to Mach3 and it never goes above 25%.
The laptop would often peg at 100% and I mistakenly though that was the problem, but when the new machine had the same random bumping and stalling, I knew there was more to it.
« Reply #4 on: December 31, 2008, 09:20:55 AM »
Interesting, you learn something new everyday -  :)
« Reply #5 on: January 04, 2009, 09:51:17 AM »
Hi
Had the same problem with my wireless mouse and keyboard
Both are wired ones now
« Reply #6 on: January 04, 2009, 10:54:04 AM »
Yes Simpson 36, my wireless network adapter reeked absolute havoc on my system while running Mach. I even got the blue screen of death several times.  :(  Ran a little CAT5 and I haven't had a problem since. I was using a d-link usb adapter. Just curious as to what you were using.
« Reply #7 on: January 04, 2009, 11:53:51 AM »
D-Link USB wireless here also!
I also had a problem with the Xbox 360 wireless controller. I bought the PC adapter and installed the plug-in and it worked as advertised. It's really a slick way to control the machine, but not at the expense of reliability.
« Reply #8 on: January 04, 2009, 12:08:17 PM »
I use a recoil usb gamepad I picked up at Walmart for $12.00 I think it was. It works great but I don't feel comfortable leaving the machine up for extended periods with it hooked up. Sometimes it will creep in an axis and has cost me a few endmills  :( .  It has to do with the centering of the axis sticks and a slight temperature change can take them off center.
Offline olf20
  •  325 325
« Reply #9 on: January 04, 2009, 05:12:50 PM »
Can you unplug a game pad before starting to cut something that will
take a long time to cut.
Just wondering, because seveal times I will leave the machine run
while I go home or off on a service call.
My game pad is USB. It has worked flawless since I put it on, but now
I"m starting to worry.  :o
Thanks olf20
Mach3, Atlas Knee Mill, 4th Axis, VcarvePro, ESS, Super PID.
Been Heating with corn since 1998
