Hello Guest it is October 24, 2026, 04:34:00 PM
Recent Posts
Pages: « 1 2 3 4 5 6 7 8 9 10 »
51
MachPro General Discussion / Re: Perfect DRO block.
« Last post by paul.stephens on September 29, 2026, 11:53:36 AM »
The easiest method, if you wish to have that, is to have a button on your widget called Edit Offsets.
You can have Edit Offsets toggle, Edit Offsets On, Edit Offsets Off. You will probably want Toggle or on.
To change this, Right click on the Widget below your DRO's → Select Configure Widget → Select "Change" on the button you want to have the button assigned to your command → Select Edit Offsets <Type> → Ok → Save.
This should give you the Edit DRO's you wish to have on the main GCode page.
You may run into the case of the text on the buttons disappearing on save, simply restart mach and the text will repopulate.
52
MachPro General Discussion / Re: Redundant Entries in Machine IO Tab
« Last post by paul.stephens on September 29, 2026, 11:43:57 AM »
This Machine I/O tab is based off of enabled signals. It will show the enabled input signals and the enabled output signals automatically. There is a current visual bug I have noticed, where - If you go into edit screen, then go into Configure → Control..., This will duplicate the Enabled inputs. Restarting Mach should resolve this visual bug. I have reported this bug to our dev team.
53
MachPro General Discussion / Re: Homing Offset in Control Plugin
« Last post by paul.stephens on September 29, 2026, 11:30:31 AM »
Just to dive in a bit deeper, what homing method are you using? Index pulse, Home in Place, Off a Home | Limit Switch?
55
Mach4 General Discussion / Mach4 shows E stop due to emergency
« Last post by Dawie Fouche on September 25, 2026, 03:09:51 AM »
 When I start Mach 4 and start the the proses to do the homing, the Mach4 shows E stop due to emergency.
I attached some videos and loggs and settings.
I cannot get to permanent clear the error.
I checked the limits; everything is fine.
I need some help, please.
56
Cabinet Wizard – New Update
Major update with improved reliability and new features:
Added Metric / Inch support
Added selectable G-code X0/Y0 positions
Improved Horizontal / Vertical panel layout
Improved Slot milling, including correct tool compensation
Added Save / Load Settings for Shelves, Drawers and Hinges
Improved BLUM Tandem runner support
Improved tool-change and spindle handling
Multiple bug fixes and safety checks
Recommended update for all users.
57
Thanks, I will do that. I had to put the router head back on for 3 days of paying work, so will reply after that.
58
Mach4 General Discussion / Re: Need Help Configuring Mach 4 on OTK Retrofit on AVID/ESS
« Last post by Bill_O on September 23, 2026, 07:22:27 AM »
I would double check the step/direction lines.
It sounds like when I have seen people swap the lines.
Also, verify the + and - on them.
Verify in the Warp9 plugin the correct pins are selected for the motor output.
59
General Mach Discussion / Re: Mach3 Problem with Threading?
« Last post by Holzwurm56 on September 23, 2026, 04:41:42 AM »
Hello Manand,
thanks for your interest. I generate the index signal using a light barrier. The signal looks good on the oscilloscope. The spindle speed is stable. I am using version R3.043.066.
Hans
60
« Last post by manand on September 22, 2026, 08:48:30 PM »
I’ve dealt with Mach3 threading problems like this before. The version does matter: the Mach3 documentation specifically mentions a major change to the threading code around R3.042.032, and that version was intended for a single-index setup. So I’d first check exactly which Mach3 build you are running.
That said, if the first 2–3 passes are correct and then the tool gradually moves off the thread, I would check the spindle index signal, index sensor, debounce setting, and spindle RPM stability before changing versions. Mach3 has to see a consistent index pulse on every revolution to synchronize the Z movement correctly.
