Mach Discussion => General Mach Discussion => Topic started by: menglor on October 03, 2013, 05:11:50 AM
Good day all,
I been lurking for a while, even fixed a few problems using the forums, but This one has me kind of stumped.
I still havent cut anything yet, I am done my conversion, and I installed my limit stops, but after watching one of the video's, I think I want to change it.
I was half hoping someone here has done it, or can point me down the right path.
My hardware:
- X2 Clone
- G540 Gecko controller and 3axis steppers
- cnc Fusion x2 kit.
So basically, I have wired up my mill using 6 limit switches all in series in a NC State, so if any trip, the whole thing stops. and that more or less works.
But after watching one of the video's, I got the impression I might get better control and better zero'ing capability if I wired up the switches independently.
But as far as I can tell, I believe the Gecko only has 4 inputs (at least that I can tell) and I need 6 to do it properly.
is it better to wire up the 6 switches independently? or can I achieve this zero'ing capability differently?
so in my Continuing research, I think I may have figured out where I goofed!
I found this article: http://www.cnczone.com/forums/gecko_drives/75368-g540_wiring_diagram_dummies.html
now, I realize this is kind of what I am trying to achieve, but it confused me because they only used 3 switches (4 if you count the A axis)
But I used 6, but after thinking about it, I am wondering Did I need to use 6? or is 3 enough, and just using the Soft limits in Mach 3 to not let it go over other end?
Hi Menglor,
I would use 6 limit switches and it will make no difference to Mach3 operation if they are connected to separate inputs or if they are all connected in series to just one input - they can still be used for homing and limit.
Hi Menglor,
I guess what I need to do is change the pin numbers for x ++ , x--, x home, y++ ... set them all to pin 1? if I understand what your saying, this seems to be the logical choice.
I am a software tester by profession, man I would soooo HATE to have to write a test plan for this thing, its SOOO many things to play with :D
