Mach Discussion => General Mach Discussion => Topic started by: ecotectoo on May 13, 2008, 04:51:37 PM
Title: Surface grinding?
Post by: ecotectoo on May 13, 2008, 04:51:37 PM
I'm pretty new at CNC and have been using Sheetcam and Mach3 for our router (fairly successfully after a couple of frustrating months)... and plan to get a CNC surface grinder later on this summer.....
I can't seem to find any info or indication that I can use Mach3 for surface grinding. Is this the case? I'll need other controller software? Any suggestions/recommendations?
-- Rich --
Title: Re: Surface grinding?
Post by: ecotectoo on May 14, 2008, 07:21:46 AM
From what people have told me, compensating for the wheel wear isn't an issue as there's some code you can insert which makes the wheel shunt aside to be automatically dressed and recalibrated.
The machine at the top of my consideration list is the Syil U2 http://www.syilamerica.com/product_u2.asp which is the least expensive and smallest CNC surface grinder I could find. The maker says that it's compatible with many software packages though acknowledges that the ones to run it in the surface grinding configuration need to be totally 3D.
Any shop I've asked only have and know about humongous machines.
We plan to be doing only ONE type of job on this machine: making reeds. The blanks are spring steel Rc55, about 1.5" x 5" x .025" thick, and need to have a shape ground from them that leaves them looking like a knife blade - but not a uniform taper. A reed's taper is slightly S-shaped going from one side at .025" arcing down to about .015" then a much larger arc to decrease the blank to about .008" then a straight portion slowly tapering down to about .005" and then another large arc to the end of the other end of the blank, ending about .003".
Historically they used some sort of pantographing surface grinder for this. My problem is that I don't want to spend forever doing trial/error to get the shape "right". We'll - it wouldn't be forever if I only had one profile to get right, but I have 44 profiles for each set of reeds and all the profiles need to be smoothly "related" it's neighbor in shape. I'm currently working on a spreadsheet to interrelate all the dimensions automatically such that after I cut one and test it, I can hand file it to adjust it and enter the new dimensions into the spreadsheet which will repopulate all the dimensions again for the next round of testing.
Other people have suggested that I get a small grinder and have it converted to CNC but I haven't been able to find anyone who does that sort of thing. And when we talk "small", I mean that the largest working area we'd need is 2"x6". Plus we don't want a large machine as our shop space is very limited.
-- Rich --
Post by: M250cnc on May 14, 2008, 11:15:22 AM
I suggest you get a small milling machine and add a grinding spindle.
To do this you would need very good dust collection or the machine will soon be ruined.
There are lots of various sized mills available and fitting a grinding attachment would be minimal compared to converting a Surface Grinder.
Plus you will have the advantage of being able to do milling on it.  ;D
Ebay or this forums bargain basement would be places to start looking.
HTH
Phil_H
Post by: ecotectoo on May 14, 2008, 01:14:00 PM
I've looked around quite a bit and haven't found any small mills that can surface grind Rc55 springsteel to +/- .0002" tolerance over 5". Besides, everyone I've talked to says that mills don't that the correct speeds and bearings to do surface grinding. So far the Syil U2 (http://www.syilamerica.com/product_u2.asp) seems to be the only thing I've found. I'm also not a machinist and don't know the first thing about choosing machinery or fitting and adjusting them.
I have a CNC routher now that I'm able to do all my milling on.
Done that but can't find anything suitable. Other suggestions of places look? Really - I've looked hard and called many places that sell machinery and have had very little luck.
-- Rich --
Post by: Sam on May 14, 2008, 10:56:43 PM
Maybe try to get in touch with Keithorr (Ed) and he might be able to point you in the right direction.
http://www.machsupport.com/forum/index.php/topic,6024.0.html
http://www.keithorrblowpipes.com/contact.htm
Post by: M250cnc on May 15, 2008, 04:13:56 AM
The machine at the top of your list is a milling machine ??????????
-- Rich --
Correct a milling machine spindle would not be suitable for grinding. But did you notice i said use a GRINDING SPINDLE which guess what, is suitable for grinding.
I am an engineer, i looked at that machine and had to laugh at the coolant nozzle when used for grinding the coolant tank would be empty in no time and the coolant would be on the floor, up the walls, all over the place.  ;D ;D ;D
There are no guards around the table to keep the coolant in check.
As you may not know you cannot do milling on a router the bigger the router the less accuracy due to flexing.
On my own milling machine i milled a 12.5 mm slot x 165mm long the length of an aluminium billet i made 50 items the tolerance i achieved was .005mm max
Phil_H
Post by: ecotectoo on May 15, 2008, 07:26:53 AM
Think you need something just a little bit bigger than what your considering.
Why? The only thing we'll be doing with the machine is grinding springsteel max of 5" long.
MSG and Enco sell a bench top surface grinder. They could be CNC'd completely ie; controller, stepper, PC, Mach software, etc. and you would be ahead of the game.
I couldn't find dimensions for the MSG but the 3 foot (plus travel?) Enco is far too large for our shop space.
I believe that MACH can run a surface grinder nicely, but some G-Code creation to address the operation of surface grinding will be in order.
I'm glad that Mach can do it and I realize that I need to find some g-code software. I'm currently using Sheetcam which I really like but isn't applicable for SG work. Any suggestions on software to convert CAD to g-code?
Remember that you grind / remove material at .0001 to .00025" with a small surface grinding machine. Grinding to tolerance is similar but a different operation than say milling a piece. There are books written on grinding and the proper application of grinding wheels to different materials not to mention sites like Norton and others on the internet.
I don't "remember" anything as I'm new to machining. ".0001 to .00025" sounds just fine by me... and I really appreciate pointers to places like Norton (never heard of them before). Thanks, I'll check them out. Please feel free to "mention" more! I need the help!
Post by: ecotectoo on May 15, 2008, 07:28:49 AM
Thanks for the links! I've just e-mailed to Keithorr and copied the stuff on that forum topic (even if I don't understand it it may come in handy at some point).
-- Rich --
Post by: ecotectoo on May 15, 2008, 07:39:33 AM
Yes but that's the only small CNC I can find that does SG. Probably not well? I don't know as I'm not a machinist and don't know my way around here. If someone would come up with a small CNC SG I'll buy it. Or if someone would convert a small SG to CNC I'll buy it. Any suggestions/leads?
Thanks for the input - I had no clue.
I don't know. That U2 seemed pretty small and heavy-duty though. But as I say... I don't know. I do know that I'll never need to grind anything over 5" long (which is pretty small?)
The stuff we need to do is grind springsteel 5" long with less than .0002" over that length... and we need to make thousands of them.
-- Rich --
Post by: vmax549 on May 15, 2008, 11:36:05 AM
Rich you may want to check on geting the reeds subed out to a grinding shop that has the right equipment to do that type of grinding. First of all trying to do micron work at the low end level is NOT easy or cheap. It take very high end grinders to maintain that accuracy day in and day out. And for the most part they are NOT small for a reason(;-) If you are really needing .0002 tolerance then you will have to WORK in the .00002 range. NOT an easy task. I can lean on my bridgeport and see more error than that. The difference from a cold machine to a warm machine is way more than that as well.  Just trying to hold something inside of that error can be a challenge in itself.
Hope that helps  (;-) TP
Post by: ecotectoo on May 15, 2008, 11:53:10 AM
I've tried 34 shops that "specialized" in CNC equipment and had CNC SG. Most said the couldn't do my stuff after I'd sent them the specs/drawings. 4 tried and gave up after a few rounds. 1 guaranteed that they could do it if I invested $20,000 to alter their machine. The last one was able to make the parts but I had to wait a month between trials and I just can't have that sort of delay.
All the people I know that make these reeds have their own machines, and those machines have been customized to make only reeds. Sounds like I should give up on the .0002" tolerance. If I do that means that I'll be hand finish profiling about 15% of our work. Not fun when we'll be going through thousands of reeds.
I was thinking that for those persnickety 15% I would work our some way of measuring them prior to doing the final passess in order to make adjustments for tolerances?
-- Rich --
Post by: vmax549 on May 15, 2008, 12:12:36 PM
You need to find a shop that specializes in CNC grinding at the micron level. BIG difference(;-) and it will not come cheap.
BUT that is not to say it cannot be done in house. You will however have to start with a high end low tolerance grinder and retrofit from there with a controller that can WORK in those tolerance ranges and have fluid movement at that resolution.
Do you have a print of an example part???
Post by: ecotectoo on May 15, 2008, 12:41:50 PM
Here's a print of 4 of the several dozen profiles we'll be needing. These are an octave apart and you can imagine what the profiles in between would look like and the ones an octave beyond in both ways.
http://home.comcast.net/~r-morse/BBox/images/reeds-e-a.gif
Here's a photo of those 4 reeds.
http://home.comcast.net/~r-morse/BBox/images/new-reeds.jpg
-- Rich --
Post by: keithorr on May 15, 2008, 02:07:18 PM
I suggested he consider sinker edm. Too easy to burn/warp stock this thin.
Post by: ecotectoo on May 15, 2008, 02:25:35 PM
Yup.... we tried EDM. This was the most successful trial. All the others cut through as the material broke free from the magchuck.
(http://home.comcast.net/~r-morse/BBox/images/sample-reed-e'''.JPG)
-- Rich --
Post by: M250cnc on May 15, 2008, 03:49:30 PM
Well I'm glad I'm not making them.
I think we can safely say that if a professional cnc grinder cannot do the job them a home built machine is out of the question.
Have you thought of wire EDM ?
Maybe forming them on a press "Would Be A Lot Quicker" then grind to width.
HTH
Phil_H
Post by: ecotectoo on May 15, 2008, 03:56:20 PM
The photo above is a wire EDM job.
I didn't know you can press spring steel into a profile??? Does it change the temper or density? Probably very expensive if you'd need to make a diferent form for each of the shapes (profiles) we need?
I was wondering about grinding them apart (to width). I figure I'd give that a try before sending it out to be wire EDM'd apart.
-- Rich --
Post by: M250cnc on May 15, 2008, 04:44:45 PM
Rich,
It would be in the realms of possibility to make your own press tool by CNC SG forget the reeds.
Its initial cost will be repaid in speed of manufacture of parts.
Virtually all springs are made by forming of one sort or another.
I have even made my own springs "Coil Compression" on a lathe with no CNC when i was an apprentice. Hell CNC wasn't even invented then.
As to their tonal quality after stamping, i don't know you would need to speak to a metallurgist.
But there are various heat treatments that maybe could help tonal quality.
More trial and error as always.
Phil_H
Post by: ecotectoo on May 15, 2008, 04:51:56 PM
Hate to be a killer of joy but you asked for additional info. That machine is not right for the quantities and what you want to do. It's your money and do as you wish.
I wish that people will tell me what I'm doing wrong and what I should be doing - and so far I'm pleased with all the advice I'm getting. Advice is cheap - buying the wrong machine expensive (and stupid!).
You need to grind wet to avoid heat.
I realize that. The Syil guys say that those photos don't show the proper coolant system that you can get with the machine. I'm also figuring that we'll need a custom chuck, splashguards, auto-dresser, etc....
No, ain't no deisgner of reeds by any means, but my father's music major instrument was the accordian. He repaired them, and hand made reads...
Sounds like you've got a good handle on what we're up against.
Now if a pro shop can't rationalize out making money on your item or knows  proper investment to meet your criteria what makes you think your going to do it for a fraction of cost and with an infearier machine.
"Pro" shops can't seem to make reeds at any price - period. We're not looking to make reeds at a fraction of the cost than we can get them from the Italians or Czech... we would gladly buy them if they cost 5 times as much as accordion reeds - but we don't want accordion reeds, we want concertina reeds - but no one makes concertina reeds for sale... so if we can't find someone to make them for us... we have to make them ourselves.
Have you ever considered changing the design of the reed?
Yes, but there's not much one can do before they're no longer concertina reeds.
-- Rich --
Post by: ecotectoo on May 15, 2008, 04:56:30 PM
I'm not sure what you mean by that. What's a press tool? Can it squish spring steel into these profiles: http://home.comcast.net/~r-morse/BBox/images/reeds-e-a.gif
-- Rich --
Post by: fabman on May 15, 2008, 07:21:41 PM
Eco,
Personally I dont see a problem with a SG conversion. I'm a toolmaker, what your talking about doesn't seem all that difficult.
How fast your going to produce these parts is a question though.
 Start with a good quality machine (a SG for sure though) , grind wet, and good quailty close pole chuck the rest is trial and error with wheel dressing routines and such. Customized fixtures would be needed to support you part but thats commonplace.The motion would be much like a mill, just my 2 cents. Good Luck.
Post by: ecotectoo on May 15, 2008, 09:25:33 PM
Personally I dont see a problem with a SG conversion. I'm a toolmaker, what your talking about doesn't seem all that difficult. =
I'm a designer and know next to nothing about machinery. It's sounding like we need to hire someone to convert a nice SG to CNC plus wet, chuck, dresser, fixtures - AND - the computer, software and all configured for us to use. I'd love some suggestions of who we could talk to for doing this.
Which I have no answer for. I don't have a clue how long it takes to grind a profile on a short piece of spring steel. 15 minutes? An hour? 3 hours? If it takes as long as 3 hours per blank then we can run two a day, 10 a work week, and we need 88 blanks for a years supply so that's.. about 2 1/2 months. That's okay by us.
Start with a good quality machine....
The start for us is for someone to tell us what are good quality machines that would be suitable for CNC conversion and some suggestions of where to look for someone to do the conversion work. I'm all ears!
-- Rich --
Post by: M250cnc on May 16, 2008, 04:11:44 AM
-- Rich --
Yes that's what a press tool does but in your case it would be a form tool.
You could go to a press tool shop and get some of your stock material shaped it doesn't have to be the shape you want any shape to get a feel of what could be achieved with a form tool this would be far cheaper than investing in a cnc grinder that you don't know is going to work
As to grinders my own experience is mainly with the "Jones & Shipman" range i do have a model 540 with optical dresser made by "Precision Grinding" "Optidress"
If you do an ebay search for "Jones & Shipman 540" you will see lots of them
My Own machine is used dry with vacuum dust extraction. Production machines are normally WET
Now comes the awkward bit my own machine tables are operated hydraulically and am sure this is the norm this will not be easy to convert
Phil_H
Post by: ecotectoo on May 16, 2008, 11:55:42 AM
In general most CAD programs will genrate a DXF for manipulation.
Yes, and my program does that. But one of the problems (and my original question on this topic) is "can I use Mach3 for surface grinding?" AND - I need some program to convert my CAD to g-code. Any suggestions?
Unless someone can directly relate from experience the pitfalls in making your specific item you shouldn't expect a concrete answer or viable solution to a production problem.
Yes I know people who make these reeds and they are being very helpful. Between them and knowing the historic ways of making these reeds it seems clear that I need to have a small high quality surface grinder which has been heavily customized to make reeds. I have lots of answers but for the specifics of which machine and who to customize it. My reed-making friends can't help me there because 2 of them use machinery which was made for making reeds over a century ago, one is rich and hired a company to make the machine and one is a machinist who spent an ungodly amount of time and money to alter his own machine to work.
Back to square one. Does anyone here know if I can use Mach3 for surface grinding? Any suggestions on CAD to g-code software? Any suggestions for a small high-quality CNC surface grinder - OR - someone to convert a SG to CNC?
-- Rich --
Post by: poppabear on May 16, 2008, 12:50:16 PM
1).  Yes Mach3 Can
2).  CAM program, How much you wanna spend? I use OneCNC XR2 Mill , but there are others Master CAM, Gibbs, Delcam, etc. you can set your cut depths in these programs, and they will all take a 3D model and machine it.
3). I can convert one for you, BUT, In your case with all the concerns involved, I would build a custom job. I would get some C-0 screws/ballnuts, all machine services ground professionally (possibly Scraped by a pro). ABEC 7's on your spindle, plus have the Spindle assembly Ground insitu to keep runout to a minumum. Again the question would be, How much you want to spend? To convert would be cheaper, but, you will be adapting the machine to do your specific job, (can be done, but you might have to make comprimizes).
Resoulution: You can go with things like AC servos with 10,000 count encoders and set up your motor profiles for some fine resoulution.
I suspect you would have to make some type of extra accomodations for Temperature control. The Tolorances your talking about even temperature can effect.  Your material, I would stress relieve it prior to machining it (IF you can do that with them).
scott
Post by: ecotectoo on May 16, 2008, 01:37:20 PM
I just called all those software places and every one of them have no info on their sites about surface grinding and when I called them they said that their software won't work on CNC surface grinders. I don't understand what's going on?
I can convert one for you, BUT, In your case with all the concerns involved, I would build a custom job. How much you want to spend?
I hope to spend under $10,000. Is that at all realistic?
-- Rich --
Post by: poppabear on May 16, 2008, 01:40:22 PM
No, your CAD/CAM alone will cost you that much.......
Post by: ecotectoo on May 16, 2008, 02:49:10 PM
Wow, I had no idea. I've been using Sheetcam which seems like great software and it cost only $150. So a 3D program costs 70 times as much? Now I'm really lost.
-- Rich --
Post by: keithorr on May 16, 2008, 02:50:16 PM
I don't think you need CAD/CAM at all for the surface grinding. I use canned cycles in Mach3 for surface grinding and wrote them longhand. If you can figure out how to build/modify a machine you'll just be doing the same thing over and over. Not like a job shop that needs fast flexible CAM post processing.
Post by: ecotectoo on May 16, 2008, 02:53:27 PM
Well, once if find someone ELSE to build/modify a machine for me... then yes, all the parts I'll be making are incredibly similar. Maybe I can hire someone to code the first one and I can use that for a template for the rest of them.
Post by: fabman on May 16, 2008, 03:16:23 PM
Eco,
            Any cam program will work with what you are trying to do. Check out Bobcad there program is very customizable, you only need to put out G-code if you plan on using Mach and you need to control 3 axis and are only going to perform a 2 axis interpulation(x&z) the y will be bumped over at the end of stroke.If all else contact me I believe I can write these for you.
Your cost would be feasible if you were doing the conversion yourself. But this is going to be a bit of work.
I believe any quality grinder will work (although you want gibs not ball ways, its a finish issue) Brown & Sharp and Thompson are a few more SG to look for. We have a small SG at our shop with coolant on it, it is by no means a production grinder. You also want tempurature controled spindle bearings some are air cooled while high end will have refrig units.
Post by: ecotectoo on May 16, 2008, 03:54:44 PM
Thanks for the reference... I just checked them out... and talked to them... and their software does NOT do surface grinding.
This all is very frustrating. I've called 5 CAM software companies today and none of them do surface grinding. Is it that there is no market for producing software that writes code for SG? I wonder why.
It certainly may come down to that.
Conversion for what a manual or automatic SG to CNC? Conversion of DXF to g-code?
Thanks... I'll check those brands out.
-- Rich --
Post by: vmax549 on May 16, 2008, 04:08:15 PM
Looking at some of the radius involved I believe you would be best served by a belt grinder. The smaller radius will require a small wheel and they do not hold shape as well as large wheels. Belt griders on the otherhand can do small radius with better finish and shape control. BUT there are problems with belts too.(;-) If the reeds are stainless then a mag chuck may be out of the question. Jigs and vacuum table comes to mind here.
All in all I would guess about $ 40-50 K to have a good reed grinder you could depend on. Could Mach do it? It would not be my first choice for this application. I would go with a Seimens grinder controller and high res AC drives. with a bottom res at .00001" .   NOT cheap or for the faint of heart.
Post by: Kristin D on May 16, 2008, 04:30:53 PM
Rich,
While they may not specificaly support surface grinding, I can't see how if you can control X,Y and Z from any software you would not be able to adapt that to grinding if you had a machine set up for CNC. It's been a lot of years since I have been around grinders but I recall we used to set them up and they would jog back and forth on their own in the X direction and increment in the Y direction mechanicaly. I can't see other than some of the points made as to wheel wear, spindle cooling and temprature control why one could not take a reasonably accurate grinder, add control motors, limit switches in place of the mechanical stops and control it's motion by software, it's a horizontal milling machine with a grinding wheel instead of a milling cutter! The real problem may be the diameter and width of the wheel in relation to the contour your looking for.
Hope I don't come off snipy, it's not my intention. I have been following this thread since it's got a lot of attention, took a while to find you were making reeds for a concertina, how do you produce the reeds now? I noticed you mentioned hand finishing a while ago in one of your posts, you may allways have to do that operation anyway since each batch may have a slightly different property. To be honest I had never thought about this sort of thing before, now you have me wondering how Honner has made harmonoca's all these years or are they all flat reeds?
Kristin
Post by: ecotectoo on May 16, 2008, 04:41:09 PM
Now that's an interesting idea. I've heard that the more modern Italian reed companies use belt grinders but I never knew what they were. You're mention of that got me Googling around. Very interesting. I'll continue to check them out.
-- Rich --
Post by: ecotectoo on May 16, 2008, 05:02:45 PM
While they may not specifically support surface grinding, I can't see how if you can control X,Y and Z from any software you would not be able to adapt that to grinding if you had a machine set up for CNC.
That's what I would assume... except that *I'm* not able to do that. I'd have to hire someone to figure it out, set it up for me, and teach me how to make (convert my CAD to) g-code files for it.
I think that's solved. The reed grinders I know either have the spindle tilted at about 2 degrees, or a titled bed, or a beveled wheel... the idea is that only a point of the wheel touches the blank to be ground. Lots of coolant and only very small point grind per pass keeps the steel from loosing it's temper. My friend who makes reeds says that for each pass he moves Y .0005" until the end of the blank and then starts over but down Z .0005" for the next series of passes. My understanding is that this is pretty much what all the concertina makers do (that use a SG).
We don't. Our current models use accordion reeds which we buy in bulk from Italy. We *have* made our own concertina reeds but they've been by entirely hand filing (only for replacement work) and some by working with machine shops to have them produce them (no joy).
Yup. Reeds always need to be hand finished. Even the best made ones in the world from the most sophisticated machines. We'd be very pleased if we'd be able to come within 20 cents (100 cents = 1 semitone) off the machine. Reeds are so sensitive that you could take a reed and it will have a different pitch if put in one part of the instrument or another part - so they have to always be fined tuned anyway. We expect that.
All those reeds have a very sophisticated and exacting multiple curvature. Hohner has an incredible wealth of reedmaking knowledge which they guard extremely well.
-- Rich --
Post by: vmax549 on May 17, 2008, 09:44:57 AM
OK now you bring up the 2.5D approach to grinding the reeds. It is an easier approach BUT very "slow" in comparison to the 3D approach. THat process Could be done on a GOOD SG with CNC controll. New machines are available.
ALSO it will require a GOOD cam package to produce reliable program code at that level of interaction. You are moving from a fluid 3d move to a series of simple moves to emulate the same effect. It gets complicated in the code required.
You asked WHY no one likes to work with SG and CNC controllers. Good quality grinding at the micron level require extemely smooth FLUID and precise motion control. Trying to use step drives always will leave a variable at each step it takes in grinding and will effect the surface finish. BEEN there done that. Even Manual grinding with power feed has the same effect there is always a transition mark left at some level. Most 3d grinder controllers have to have extremely good fluid like motion control to produce a quality micron finish. HENCE matched components and HIGH $$$$$.
SO if you are going to have to HAND tune each reed anyway then the extreme griding tolerance is really NOT a factor. Just a good repeatable profile down to a usable tolerance.
In the beginning you mentioned 1000s of reeds but later mentioned  only a few 100 a year. (;-) There is a big difference in what you can get away with machine wise there.
????? Are your reeds stainless steel???  or just tool steel. How do you deal with rust if not stainless ??
Post by: ecotectoo on May 17, 2008, 10:52:17 AM
By "that" process do you mean the 2.5D or 3D?
So it sounds like I should be able to get a machine to grind reeds with a 2.5D package? Show me the way!
Yes. I'm hoping that we'll be able to achieve results within 20 cents.
Hmmm... Sorry about the error/confusion. There are 44 pitches of reeds we regularly use (and rarely about 24 higher and lower pitches) and our first years run of concertina-reeded boxes is expected to at least 30 boxes. Each box usually has 2 same-pitch reeds... so 2 reeds x 30 boxes = 60 same-pitch reeds/year. If each blank we grind can be split into 30 reeds that means we'd need 2 blanks x 44 pitches = 88 blanks ground for our first year's production. Just 88 little 4" blanks of steel will yield us 2600 reeds. That's rock bottom minimum. As some of our models have more than two notes of the same pitch (each note has 2 reeds) then more realistically we'd be needing maybe 100 planks = 3000 reeds.
If we were to replace all the accordion reeds we're using in our current models of concertinas with concertina reeds then we'd have to come up with about 350 more ground blanks = 10,500 reeds.
Our reeds are spring steel (not stainless, not tool steel). We don't deal with rust because rust isn't an issue unless one plays constantly in extremely humid conditions (like on a boat on log ocean voyages) in which case you can get concertinas with stainless steel, brass or phosphor bronze reeds (which are very rare). In my 30 years of making and repairing accordions an concertinas I've come across only 2 cases of rusty reeds, and both were due to the boxes being submerged in a basement flood and left to moulder for weeks.
-- Rich --
Post by: vmax549 on May 17, 2008, 12:02:56 PM
(;-) You must be in a really dry climate. In FLorida if you leave a piece of ground steel exposed for a few minutes it rusts.
Look on the Web for NEW small CNC surface grinders. they really don't get very small though(;-) Some smaller than others.
Post by: ecotectoo on May 17, 2008, 02:23:10 PM
Concertinas are played all over the world though mostly in English-speaking countries like the UK, Ireland, Canada, the USA, South Africa, New Zealand, Australia.... Accordion reeds are made very similarly, and of the same materials as concertina reeds are, and accordions are played pretty much everywhere. Rust isn't much of a problem at all. Even for accordions in Florida.  :-)
-- Rich --
Post by: ecotectoo on May 19, 2008, 08:02:01 AM
I've been checking out some of those machines/sites. Incredibly expensive and overkill for what I want to do? One good thing though - I just found out that there's a big machinist trade show just down the road from me called Eastec (http://www.sme.org/cgi-bin/get-event.pl?--001743-000007-020773--SME-) which opens tomorrow. Talk about good timing! There seems to be thousands of manufacturers and vendors there. Does anyone have suggestions on who I should check out for small CNC surface grinders and software to run them?
-- Rich --
Post by: vmax549 on May 19, 2008, 01:13:08 PM
Like we have said CNC grinding is NOT cheap. Just extremely accurate if done correctly. And tiny lightweight grinders HAVE their problems.,lack of mass and dampning and rigidity. Don't forget the grinding cam Package as well.
Now you know why the old copy/plate  grinders that used templates stayed around so long. (;-)
