Mach Discussion => General Mach Discussion => Topic started by: montejw on March 03, 2008, 06:49:42 PM
Title: Mach3 on 64 bit Windows XP? "No Driver sensed installed. Run Driver Test"
Post by: montejw on March 03, 2008, 06:49:42 PM
I just installed Mach3 on Windows XP Professional x64, the 64 bit version of XP.  Tried DriverTest.exe, got the error message "No Driver sensed installed.  Run Driver Test.", so I did, and I got the error message "No Driver sensed installed.  Run Driver Test.", so I did, and I got the error message "No Driver sensed....
Well, I really only ran it once.  Or twice.  Anyway, has Mach3 been run successfully on 64 bit Windows XP?
If you've seen my other thread, I reinstalled Windows XP (32 bit) on that computer, reinstalled Mach3, and I still have the same problem.  I'm looking at other things now, harmonic dampers for the steppers and such.  But I thought I'd try to run Mach3 on a different computer, and the 64 bit XP is the only other one I have.
Monte
Title: Re: Mach3 on 64 bit Windows XP? "No Driver sensed installed. Run Driver Test"
Post by: garbo.hunter on April 27, 2008, 08:40:51 AM
Same experience here except on Windows 2000. Error message during install - while too quick to read in detail it is clear that it pertains to a driver issue.
Same message when running driver test.
Installed the special drivers, no difference.
What drivers is the programme looking for?
Tom
Post by: Hood on April 27, 2008, 11:09:35 AM
Have you guys tried reinstalling Mach over the top of itself again? Also look in device manager and see if the pulse engine is installed.
Post by: montejw on April 27, 2008, 11:15:44 AM
I'm now using the Smooth Stepper, so it's a non issue for me.  I haven't tried the SS on the 64 bit computer since the other one is now working well.
Monte
Post by: Hood on April 27, 2008, 11:20:02 AM
Great, thats a BIG plus of the SS, it will let you use computers that previously had problems running Mach such as laptops :)
Think Greg is on to a real winner with it.
Post by: DavidJ on January 24, 2009, 12:40:58 PM
I just loaded Mach3 on my x64 Windows XP machine, after deciding previous PC was below marginal for meaningful use.  I get this 'No driver sensed....' error.  Running Driver Test just repeats the same error.
Has anyone got Mach3 to run on the x64 version of XP Pro ?  I'd like to understand if I'm wasting my time, or if it might be a PC specific issue...
Post by: ger21 on January 24, 2009, 02:16:24 PM
I don't believe it will run in 64bit OS's.
Post by: DavidJ on January 24, 2009, 03:27:44 PM
Thanks - looks like I'll have to find another PC to use.
Post by: Dan326 on February 21, 2009, 01:21:58 PM
Need to know how to access "driver Test". Please help. New to Mach3.
Post by: Hood on February 21, 2009, 01:38:48 PM
Make sure you dont have Mach running, browse to the Mach3 folder on your drive (default is C:\Mach3) and double click on the file called DriverTest.exe.
Post by: Dan326 on February 21, 2009, 04:13:14 PM
Dear Hood,
     I have tried all. Enabled the 2-7 pins in ports and pins. Also changed them to active low (on and off). Did the driver test. Came back excellent. And several other things.
     If I uninstall and reinstall, I know I would have to begin again but it that the right thing to do at this point?
Dan326
Post by: Hood on February 21, 2009, 05:16:13 PM
What exactly is wrong?
If you install over the top of itself you will not lose settings but it is always wise to copy the xml file for the profile you are using and if you ever lose your settings you just paste it into the Mach folder and you are back in business.
