Mach Discussion => General Mach Discussion => Topic started by: fredech on March 10, 2019, 08:08:24 AM
Hello everybody
Something odd happened to me:
Set and Goto variable position (in the MDI tab) do not work anymore:
X is fine, but Y and Z always want to go to the 0 machine coordinates.
I checked everything I could (macros and config) but everything seems to be ok.
I'm a bit lost...
any idea about the problem ???
Fred
Hello everybody
I'm a bit lost...
Fred
I am only guessing.
You are probably NOT at G54 offset (ie. Work Offset#1)?
I just found the issue
the macros were altered for a reason that remains a mystery...
I just copied all macros from a backup file and everything came back fine :)
thanks anyway !
