Mach Discussion => General Mach Discussion => Topic started by: riphet on February 13, 2013, 07:57:06 AM
I setup the Spindle PWM and work.
But I wonder.
Why PWM signal does not accelerate or decelerate?
When I switch to M3,
immediately sends pulses of "S" (speed), without accelerating.
When I turn to M5,
immediately turn off the pulse train.
Mainly I'm interested in accelerating the switch.
for example with M3S15000
When I change M3S12000 speed, M3S14000, M3S16000 ... changing the pulse train without acceleration.
It is normal that sends Mach3 PWM signal without acceleration?
What I look for is a soft start motor.
Hi Riphet,
I am no expert here but in all the cases I have seen...
The motor Acceleration and Deceleration times are specified parameters within the VFD manufacturers setup menu.
Once the CW run signal (M3 in Mach) is received by the VFD, the motor will accelerate up to the actual PWM requested speed over the pre-set time interval. The motor then follows a similar pre-set deceleration interval when the CW run signal (M5 in Mach) is removed.
But I wonder.
When I turn to M5,
Mach3 does not use the motor tuning acceleration values for the Spindle axis when generating the PWM signal through the parallel port.
That said the SmoothStepper does use it when generating the PWM output.
Cheers,
Peter
Hi Riphet,
Thank you very much
I'm poor, I have no VFD.
Only use a simple triac with optocoupler.
But I wonder.
When I turn to M5,
Cheers,
Peter
After trying several configurations,
I suspected: Mach3 ignored and no use some tuning values for the Spindle.
Maybe not use all values of motor tuning?
Then only work with Spindle SetUp, Motor Control:
Check use spindle motor output
Check PWM control.
PWM Base and minimum PWM
and that's all.
The motor tunning and setup is ignored by Mach3 (case Spindle). ???
Independently, moreover:
Of course I'm interested in very high quality pulse train.
So I need an FPGA board with wireless, cheap for a poor.
I'm in cheerful.
I appreciate your time and attention.
