Mach Discussion => General Mach Discussion => Topic started by: nemoc on January 16, 2011, 12:53:40 PM
Title: Pullback DRO
Post by: nemoc on January 16, 2011, 12:53:40 PM
Could someone tell me what are the OEM 91 and 93 DRO?
 How do they work?
 OEM 91 is the pullback DRO?
thanks
Nemo
Title: Re: Pullback DRO
Post by: Hood on January 16, 2011, 01:00:04 PM
OEM 91 is G73 Pull-off value DRO and I would imagine that would be the value that the retract would be in the G73 cycle
OEM 93 is Tangential lift Z level DRO which I would image would be the value the Z is lifted before a rotation of the tangential knife.
Post by: nemoc on January 16, 2011, 04:19:50 PM
Thanks Hood!
 I'll put one OEM91 DRO on the screen , and I'll do a test with G73.
Must be more fast and better than the G83 with a Center Drill . Or not??
Nemo
Post by: Hood on January 16, 2011, 04:28:19 PM
Look forward to the results, not sure if I have ever used it but I seem to remember that DRO being on a screen before but cant find it now.
Post by: BR549 on January 16, 2011, 04:54:34 PM
It is in config, ports/pins, mill setup
Post by: Hood on January 16, 2011, 04:57:28 PM
Knew I had seen it somewhere, thanks
Post by: nemoc on January 21, 2011, 01:35:41 PM
 I did a test and I am satisfied with the results.
Hood & BR549...Thank  you all.
Nemo
Post by: Hood on January 21, 2011, 01:46:51 PM
Good to hear.
