Hello Guest it is September 19, 2026, 08:34:44 AM
Author Topic: mcX360 Plugin for Lua  (Read 230708 times)
0 Members and 4 Guests are viewing this topic.
Re: mcX360 Plugin for Lua
« Reply #70 on: August 10, 2018, 09:01:39 AM »
another dumb question
where does the code actually get stored, file location. i know i can do a save as and put a copy were i want for safe keeping
but when i create a pannel and add code were is that kept
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #71 on: August 10, 2018, 01:57:58 PM »
The code is embed into your screenset and is only editable through the screen editor.
DazTheGas
« Reply #72 on: August 14, 2018, 02:43:29 PM »
is there a  way to check the status of a button on the Mach 4 form  ie the Enable/Disable button
i am using the A button on the Xbox controller to toggle the Enable/Disable button but had to resort to a flag (local ToggleState) to see if it has been enabled  by my code
only problem with doing it this way is it assumes that it is in the disabled state to start off
using
mc.mcCntEnable(mIst, 1) to go from disable to enable
and
mc.mcCntEnable(mIst, 0) to go from enabled to disable
it would be nice to test the current state first before setting it to another state
« Reply #73 on: August 14, 2018, 05:05:04 PM »
Figured this one out also.  :)
what is the best way to do a Velocity move in X, Y, and Z axis
currently i am using
mc.mcVelocityStart(mInst, Axis, direction)
but speed is from the Slider on the Mach4 panel and the Jog DRO
So i have to keep changing those values as RTHY and RTHX values change from 0-90 (i have a dead spot -30 to +30
while this works it is messy
is there a better way to do a velocity move
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #74 on: August 16, 2018, 06:29:03 AM »
There are some good examples in the Screen Load Script of the stock wx4 screenset, take a look at the Spindle functions.
I use
Code: [Select]
-- Start Button
if GetXin("Btn_START") == 1 and Start_Btn == false then
        local mcCntlEnable = mc.mcSignalGetState (mc.mcSignalGetHandle (mInst, mc.OSIG_MACHINE_ENABLED))
        if mcCntlEnable == 1 then
            mc.mcCntlEnable(mInst, 0)
        else
            mc.mcCntlEnable(mInst, 1)
        end
Start_Btn = true
    end
    if GetXin("Btn_START") == 0 and Start_Btn == true then
--Release Command if any
Start_Btn = false
    end
To set the velocity you just need to take a value from the thumbstic and set mc.mcJogSetRate as a percentage so the further you push the stick the faster it moves.
DazTheGas
Offline mhd
  •  11 11
« Reply #75 on: September 19, 2018, 02:28:04 PM »
This was made for an XBox controller only.
DazTheGas
First of all, thank you for the good video
You say that the lua you but it only for XBox 360 but I hook my the PS3 controller and check the Register Diagnostics /mcX360_LAU and it gives me a value!!
The problem in my case that when I try to code the software help me with the function. because I'm not that good in coding and I'm learning from your video.
Like when I type (Local or mc.mcRegGetHandle) it the software help me find them
but in case of (mc.mcGetInstance(), Start) there is NO option to select from.
Did I do something wrong?
Best regard
shrooqi
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #76 on: September 19, 2018, 03:52:24 PM »
It would be easier to post what code you are using.
DazTheGas
Offline mhd
  •  11 11
« Reply #77 on: September 20, 2018, 04:31:35 AM »
as I motion that the Register Diagnostics /mcX360_LUA give me a value when I press any bottom
I follow your video step by step and this is the code
 ------- Declaer local---------------
local mInst = mc.mcGetInstance()
local Xenable= 0
-------------- Ps3 Init Panel------------
Ps3_Penal = wx.wxPanel( wx.NULL , wx.wxID_ANY , wx.wxDefaultPosition , wx.wxDefaultSize)
Ps3_Timer = wx.wxTimer (Ps3_Penal)
Ps3_Timer : Start(100)
----------- Function----------------
function GetXin(Xinput)
   local hreg = mc.mcRegGetHandle(mInst , string.format("mcX360_LUA/%s") , Xinput)
   return mc.mcRegGetHandle(hreg)
end
------------Event Timers-------------
Ps3_Penal : Connect (wx.wxEVT_TIMER , function(event)
      if GetXin("LTR_Val") > 150 and Xenable == 0 then
         Xenable = 1
         mc.mcCntlSetLastError(mInst , "Ps3 Running")
      elseif GetXin ("LTR_Val") < 50 and Xenable == 1 then
         Xenable =0
         mc.mcCntlSetLastError(mInst , "Ps3 Stopped")
      end
   end   )
Offline mhd
  •  11 11
« Reply #78 on: September 22, 2018, 01:37:40 PM »
DazTheGas
local Xenable= 0
end
         Xenable = 1
         Xenable =0
      end
   end   )
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #79 on: September 25, 2018, 08:28:12 AM »
Your GetXin function is incorrect
your code
Code: [Select]
   return mc.mcRegGetHandle(hreg) -- This line is wrong
end
code should be
Code: [Select]
function GetXin(xinput)
local hreg = mc.mcRegGetHandle(inst, string.format("mcX360_LUA/%s", xinput))
return mc.mcRegGetValue(hreg) -- or return mc.mcRegGetValueLong(hreg)
end
DazTheGas
