Hello Guest it is September 12, 2026, 03:37:38 AM
Author Topic: Modify Button Output  (Read 21253 times)
« on: July 29, 2012, 06:48:49 PM »
I would like to modify the softlimits button to activate an output when pressed, then deactivate it when pressed again.
I can get it to activate with a VB script of ActivateOutput(7)......but I can't shut it off.  This is pretty new to me, so I'm making very slow progress....lol.
I though maybe using a toggle type button would work, but it hasn't so far.
I wonder if I need a conditional script.....but don't know.
Any help would be appreciated.
Mike
Re: Modify Button Output
« Reply #1 on: July 29, 2012, 07:33:03 PM »
Typically, you'd check the status of an LED to determine the status of the output, and turn it on or off based on the LED's status.
Like:
 If GetOEMLED(xx), then
deactivateoutput
else
activateoutput.
endif
I don't know the actual syntax off hand, so the above is just for reference. :)
« Reply #2 on: July 29, 2012, 09:33:39 PM »
That did the job.....Thanks a bunch.
Mike
