Mach Discussion => Mach Screens => Screen designer tips and tutorials => Topic started by: michaelthomas on July 29, 2012, 07:48:49 PM
I would like to modify the softlimits button to activate an output when pressed, then deactivate it when pressed again.
I can get it to activate with a VB script of ActivateOutput(7)......but I can't shut it off. This is pretty new to me, so I'm making very slow progress....lol.
I though maybe using a toggle type button would work, but it hasn't so far.
I wonder if I need a conditional script.....but don't know.
Any help would be appreciated.
Mike
Typically, you'd check the status of an LED to determine the status of the output, and turn it on or off based on the LED's status.
Like:
If GetOEMLED(xx), then
deactivateoutput
else
activateoutput.
endif
I don't know the actual syntax off hand, so the above is just for reference. :)
That did the job.....Thanks a bunch.
Mike
