Hello Guest it is June 17, 2026, 06:31:01 AM
Author Topic: motor steping  (Read 7087 times)
motor steping
« on: June 06, 2012, 06:22:44 PM »
i have set my mach 3 to cut a grid on my table 2 inches apart both the y axis and the x axis direction,  the x axis cuts every 2inches like it should butt my y cuts every 1.5 my motors are set the same in the config motor tuning page i wounder if the y has the wrong Greer on it can any one help?
  •  9,356 9,356
Re: motor steping
« Reply #1 on: June 08, 2012, 01:27:39 AM »
Just a thought but if your controller has microstepping are both the X and Y drivers set to the same value of microsteps ??
Re: motor steping
« Reply #2 on: June 09, 2012, 07:19:27 AM »
Being as your y moves exactly 1.5" and the X 2" and your microsetting for both axis are the same it looks as if you have different gear ratios driving the leadscrews. The Y might have a ratio of motor 4 revs to one leadscrew turn and the X, 3 revs on the stepper motor to one leadscrew rotation. Try using the axis measurement setting in the motor config setup menus. Might be completly wrong but worth a try.
