Hello Guest it is December 17, 2025, 01:41:49 AM
Author Topic: Windows 7 config problems  (Read 10743 times)
« on: March 04, 2011, 12:40:04 AM »
Configuring Mach on Windows 7, using device manager to get port address of PCI parallel card it indicates a port address of EC03-EC07, this will not allow the port to work. Has anyone else had this situation, and how did you determine the actual address??
Win 7 runs programs better than Vista, but hides too many things from user access.
Thanks for your help.........I did search first.
jim  :)
  •  9,327 9,327
Re: Windows 7 config problems
« Reply #1 on: March 04, 2011, 02:07:47 AM »
Hi Jcburn,
Welcome to the forum.
The port address you would then enter into Mach would be EC03 (make sure you enter a zero not an O   ;) ) It will then look like 0xEC03 indicating that it is Hex notation.
Hope this helps.
« Reply #2 on: March 04, 2011, 12:10:52 PM »
 ;D Thank you!!!!
I put the address indicated in resources in the field as you instructed and they now talk to each other  :D
I appreciate your quick response, I've lurked for years and finally got around to setting my machine up.
Thanks again,
jim  8)
« Reply #3 on: December 20, 2011, 10:55:56 AM »
I am having a similar problem and have tried to change the address to 0xE010 as shown in my device manager. the os is windows 7.
  •  9,327 9,327
« Reply #4 on: December 20, 2011, 11:37:26 AM »
If you just type E010 then Apply then close the box, next time it is opened it will display 0xe010.
« Reply #5 on: December 20, 2011, 11:53:03 AM »
I did that, still no communication between mach 3 and the parallel card.
« Reply #6 on: December 20, 2011, 01:10:07 PM »
never mind, I have a 64 bit os.  :( any one have suggestions on the best way to go about this issue before I go find an old dinosaur? All the external motion control stuff I have found costs more than a old tower.
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #7 on: December 21, 2011, 08:58:28 AM »
But is will work better than any old tower too, and it will work the same on what ever PC you put it on...
Happy machining , Jeff Birt
