Hello Guest it is September 09, 2026, 07:56:49 AM
Author Topic: Need help  (Read 11726 times)
Need help
« on: March 30, 2009, 07:33:24 AM »
HI I am new in cnc machines and i have problem to config my cutting speed when i load some file for example 1 line which is long 1 meter mach3 cut this for 1 min.My question is how to cut the same line for 10 sec .What I have to change.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Need help
« Reply #1 on: March 30, 2009, 12:19:25 PM »
The F command controls the feed rate of the axis, if you are working in metres then the feed you have is F1000. to move 1 metre per minute,  to make it move 1 metre in 10 seconds then you have to move 6 times faster so F6000. will do this.
Graham
Re: Need help
« Reply #2 on: March 31, 2009, 09:53:14 AM »
Thank you I tried and works Actually before to load file in mach3 i can adjust my feed rate in lazycam I think .
But thank you for the fast answer.
I need that because I'm building plasma table (X=1m y=2m) I will  cut about 1 mm steel  thats I need fast cutting speed.If you can somebody can give me some tips I will be happy to learn.
« Last Edit: March 31, 2009, 10:01:47 AM by keeman00 »
