Hello Guest it is June 11, 2026, 12:53:53 AM
Author Topic: Any one tried a MPG with the PoKeys?  (Read 36850 times)
« on: December 02, 2008, 03:39:15 PM »
I fitted up my pendant the last day and the MPG worked after a fashion, as long as I didnt wind too fast it was fine, if I wound a bit to fast it would just stop responding.
Anyone else tried it?
Re: Any one tried a MPG with the PoKeys?
« Reply #1 on: December 03, 2008, 04:09:39 PM »
Hi Hood,
I'm interested in a Pokeys for use on an Orac conversion project. I need the MPG for X & Z handwheels so I can use the machine CNC or manual "fly by wire".
So if anyone has had sucess, I'll def order a Pokeys.
ATB
Derek,
You can "chop it off" but can't "chop it on"
« Reply #2 on: December 03, 2008, 04:34:58 PM »
Derek
 It does work, just its not as good as the parallel port for normal use, the step use is much better on the pokeys than the parallel port however.
« Reply #3 on: December 31, 2008, 01:35:11 PM »
How should I configure MPG in Mach3 ? I have it working OK in PoKeys-configuration software, it's showing values from 0->254 just ok. But when I tried to use MPG #1 in Mach3, it outputs strange values (tens of thousands of clicks per one unit) to the MPG calibration screen. Something I'm missing. I don't have any Brains configured for MPG-input, I'm using Brains just for analog FeedOvrd for now.
With best regards from Finland & Happy New Year !
Henry "Henkka" Palonen
« Reply #4 on: December 31, 2008, 02:34:44 PM »
Hi Henry
 You just configure like you would a normal MPG, then use the calibration wizard to set it up correctly. Mine works fairly well via the PoKeys but if I wind too fast then it will just stop any motion until I wind slower, seems to be the plugin doesnt read the data fast enough. As you say the PoKeys software itself seems to have no problems reading the MPG. I am not using the PoKeys at the moment as I am rebuilding my pendant but unless there is an improvement in the speed response of the MPG via the PoKeys plugin then I will just use the SmoothStepper inputs for it.
 Have you enabled the MPG in the Plugin?
« Reply #5 on: December 31, 2008, 02:47:08 PM »
It's working ok now. I restarted the machine & Mach and did some other button-configurations in the meantime.
Here is the configuration I'm using for PoKeys55T MPG:
1) In Config->Ports & Pins ->MPG config;
1a) enable, A-port = 10, A-Pin = 1, B-Port = 10, B-pin = 2
2) "Plugin Control"-> "PoKeys Conf" -> "Use Encoder5 - MPG1" is checked
After that it seems to work OK, albeit little slow. I can't judge yet how actual milling machine will perform,
since I'm running Mac OS X and on top of that VMWare virtual machine where the Mach3 & PoKeys is run in the Windows-machine. There might be some
lag issues due to my machine setup. As soon as I wire the rest of the buttons & configure the PoKeys, I'll transfer the setup to the actual workshop-machine.
With best regards & Happy New Year from Tampere / Finland,
Thanks for your quick reply.
« Reply #6 on: December 31, 2008, 02:50:38 PM »
Henry, what date is the plugin you have? The earlier ones had a fair bit of lag, the one I am using is dated 22/11/2008
« Reply #7 on: December 31, 2008, 02:54:28 PM »
Yes, the date is same. I got the plugin from PoKeys homepage, that had same date as that post had (the post where the new plugig was attached).
Henkka
« Reply #8 on: December 31, 2008, 02:57:44 PM »
Please let me know how it works out for you, as I siad it seems to work every bit as good for me as the one via the parallel port (actually SmoothStepper now) with the exception that if I wind too fast it stops responding.
Offline Don C
  •  26 26
« Reply #9 on: February 11, 2009, 06:47:21 PM »
What MPG are you using with pokey55.
  Don :)
