Hello Guest it is June 11, 2026, 07:56:41 PM
Author Topic: pokeys analog  (Read 116132 times)
pokeys analog
« on: October 20, 2008, 05:29:26 PM »
any one know how use analog inputs in mach3 for speed override, spindle override, ?
i tried use brain  it recognizes the analog input but i dont know how terminate the rug for implement the two overrides.
Josep.
Offline borisz
  •  220 220
    • www.poscope.com
Re: pokeys analog
« Reply #1 on: October 21, 2008, 12:21:19 AM »
It might not be THE information, but as I remember, Analog are not yet implemented yet in Mach plugin.
Art?
regards
Boris
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
Re: pokeys analog
« Reply #2 on: October 21, 2008, 05:58:04 AM »
Are there others ways to use a potentiometer to control the feed and RPM on Mach3.
I saw a video on you tube showing that.
Re: pokeys analog
« Reply #3 on: October 21, 2008, 06:08:41 AM »
can you explain a litle more??
josep
« Last Edit: October 21, 2008, 05:35:57 PM by gifre70 »
Re: pokeys analog
« Reply #4 on: October 21, 2008, 12:30:46 PM »
I have not tested it yet but Analogue Inputs via the Pokeys are in the latest plugin.
Re: pokeys analog
« Reply #5 on: October 21, 2008, 01:54:19 PM »
The analog inputs do work.  I was able to hook them up and get them working this morning.  However, I am experiencing a bit of a delay from the analog switches.  The pokeys software reacts almost instantly but mach seems to have about a 1 second delay pulling the information in.  I wrote a simple macropump to control the FRO and it does work.  It very well could be my inexperience with mach, but I am very pleased to see that it is working even if it does need some minor tweaking.
Re: pokeys analog
« Reply #6 on: October 21, 2008, 02:18:43 PM »
I think there may be problems with the plugin as I have tried with a MPG hooked up and Mach has a big delay when winding the MPG. Art is in the UK at the moment so hopefully when he gets back he can have a look but certainly sounds like a similar issue that you are having with the analogue (analog for you USA guys ;)  )
Re: pokeys analog
« Reply #7 on: October 25, 2008, 05:15:39 AM »
Hi All,
I've acquired a nice little Orac with a tool changer and are going to convert it to Mach 3.
I have already converted a Bridgeport to M3 but this is a basic system with just 1 standard breakout board+ shuttle.
Looking at the i/o extension options for Orac, the Pokeys looks great as I would like to :-
Operate the tool change (3 position sensor  i/p and 1 o/p to index).
Fit MPG handwheels to give "manual machining control"
Travel limits
Speed and spindle speed override pots.......so far so good I think 8)
Also, op a 0-10v analogue signal to a new VFD for spindle control, I'm not sure if Pokeys does this yet? I (think) I will need to somehow isolate the analogue from the VFD?
Any ideas or advice would be appreciated.
ATB
Derek.
You can "chop it off" but can't "chop it on"
Re: pokeys analog
« Reply #8 on: October 25, 2008, 08:36:13 AM »
The Pokeys does the analogue in and the MPG at the moment but its not perfect and needs a bit of work. The MPG has a fair bit of delay from my testing and hopefully this will be made better, not sure if its a plugin issue or Pokeys.
 For spindle control  you want to look at the Digispeed from homanndesigns.com There are others that do similar.
Re: pokeys analog
« Reply #9 on: October 25, 2008, 12:22:52 PM »
Hi Hood,
I like the look of the Pokeys as it appears to be an "all in one" for just about all my add-on needs and was hoping that it would O/p to the VFD to make a realy neat installation.
If not, the Pokey is still looks good and I'll fit a digispeed / other for the spindle speed control.
I did make a PWM to volt converter for my BP driven by the op from the PMDX but it hunts a bit so I will change this at the same time as fitting to the Orac.
ATB
Derek
