Hello Guest it is June 12, 2026, 09:20:14 PM
Author Topic: Art has posted new plugin  (Read 92582 times)
« on: October 13, 2008, 06:59:36 PM »
Heres what Art has to say and also have attached the plugin.
Hi Guys:
New dev version PoKeys.m3p is in the files section for testing. It will accept
up to 7 encoders, but is untested in that regard. It uses new firmware that you
have to download from poKeys ( PoKeys55) ..
When turning on encoders, you must set them to port#10 in MAch3, and the
encoders used must be numbered from 1 - x in order in the plugin. In other words
if you turn on only #5 and #6 which are MPG encoders, then you need only
encoders 1 and 2 turned on in the pokeys. You dont need to turn on 6 of them and
then only use #5 and 6.
Again, untested except for basic IO. Analogue's .. up to 4 .. are read as well
if available and put in the same spot the G100IO uses ( registers 124 - 127 )
for use by brains. The analogue inputs are all 16 bit.
No analogue out has been added, Ill add that in future when the current encoder
tests and analogue input testing is complete.
Art
Re: Art has posted new plugin
« Reply #1 on: October 13, 2008, 07:15:47 PM »
Hood, I'll probably have to ask Boris about this but do you know if there's a way to update the Pokeys Firmware without having to be connected to the internet? In other words, a separate downloadable file?
« Reply #2 on: October 14, 2008, 01:57:41 AM »
dont have a clue I am afraid.
« Reply #3 on: October 14, 2008, 05:07:42 PM »
Just spoke (emailed) with Boris, he said you can just download the software and that's it.
« Reply #4 on: October 15, 2008, 05:03:54 PM »
Good to know Dave, thanks.
 I have been too busy soldering up circuit boards the last few nights  to set the pokeys up with an encoder but hope I can tomorrow evening. Have you tried it yet?
« Reply #5 on: October 15, 2008, 05:31:24 PM »
No sir, not as of yet.
I've just been swamped all of a sudden with my "side job" work to even setup the new software, let alone connect an encoder that doesn't even exist   :D
« Reply #6 on: October 15, 2008, 06:29:47 PM »
LOL, oh well hopefully I will get a chance tomorrow evening or should I say this evening as its after midnight now
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #7 on: November 20, 2008, 12:37:36 PM »
New, faster plugin for PoKeys55 is published on htttp://www.poscope.com
Thanks Art.
Z lepimi pozdravi / With best regards
Boris Zalokar
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
« Reply #8 on: November 20, 2008, 12:39:53 PM »
Just tried the one that Art posted on the Yahoo group and it doesnt work for analogue or MPG. I will try the one posted on your site and see if that helps.
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #9 on: November 20, 2008, 12:45:34 PM »
It was released today.
