Hello Guest it is November 04, 2026, 09:27:44 AM
Author Topic: Art has posted new plugin  (Read 99302 times)
Re: Art has posted new plugin
« Reply #10 on: November 20, 2008, 12:48:48 PM »
Yes that is correct, Art posted on the Yahoo a few hours ago and it doesnt work for me, have also just downloaded from your site and again not working. I will check and see what the PoKeys software is reporting to see if it is something else wrong.
« Reply #11 on: November 20, 2008, 12:55:44 PM »
PoKeys software shows both MPG and Analogue working correctly but no response in Mach. If I revert to the previous plugin both are working again.
« Reply #12 on: November 20, 2008, 01:32:14 PM »
Upgraded to latest firmware and it is now again working. MPG response
is much faster although it is just on the desktop and not actually
controlling any motors but would think it to be fine.
Analogue still a bit funny, if I wind the pot down  too fast then the FRO
DRO may end up at any number between the 146% and minimum, usually
between 30 and 6. Winding it slowly it works fine. Winding up the way to max  at any speed always results in the 146% which is correct.
« Reply #13 on: November 20, 2008, 01:52:41 PM »
Analogue FRO does not seem to work now when actually running the code. Do a feedhold and the DRO will update and the analogue start working but start the code again and it again stops working.
« Reply #14 on: November 20, 2008, 05:00:37 PM »
Sorry to keep reporting things but the MPG doesnt seem to work in any mode other than velocity, step and multistep dont work.
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
« Reply #15 on: November 20, 2008, 05:43:37 PM »
hood..
 Ill check it out. I take it all inputs work except during running of code as well?
Art
« Reply #16 on: November 20, 2008, 06:09:18 PM »
Just tried an Input and it is very slow to react when code is running but does eventually.
« Reply #17 on: November 23, 2008, 05:16:51 PM »
Hood,
What FORMULA are you using in the BRAIN for your analog input for the FRO.
Darek
« Reply #18 on: November 23, 2008, 05:20:46 PM »
Hood,
Darek
A/7
« Reply #19 on: November 23, 2008, 05:22:53 PM »
Try (A/7)+.1
