Hello Guest it is June 12, 2026, 12:27:27 PM
Author Topic: DXF import  (Read 16877 times)
Vmax
DXF import
« on: December 14, 2005, 08:42:58 AM »
When I bring in a DXF 2d drawing how is the best way to control the Z axis. Do I just manually change the code for the different heights or can I set up the drawing and put the different height sections on separate layers before I import it?????  Thanks Terry Parker
Re: DXF import
« Reply #1 on: December 14, 2005, 10:15:14 AM »
The best way is to use the layers for the depth's
Hope that helps
Brian
www.newfangledsolutions.com
www.machsupport.com
