Hello
Guest
it is
June 10, 2026, 09:20:22 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Code file
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Code file (Read 10788 times)
Loui
8
Code file
on:
September 19, 2008, 03:55:27 PM »
I have been running Mach 3 for a while now and just had to switch computers and now I have a problem. I have a M30 comand at the end of a program and when I load it in Mach3 you do not see it and it does not rewind the program. Any ideas? Thanks
Carnoustie, Scotland
Re: Code file
Reply #1 on:
September 19, 2008, 03:57:03 PM »
You need to have a return after he last line in your code or it will not be seen. It is good practice to put a % after the last line of code as that insures you have moved onto the next line
Loui
8
Re: Code file
Reply #2 on:
September 19, 2008, 04:03:19 PM »
Thanks for the quick reply. Problem solved.
Print
Pages:
1
Go Up
« previous
next »
