Hello Guest it is November 17, 2026, 01:43:44 AM
Author Topic: Code file  (Read 13004 times)
Code file
« on: September 19, 2008, 03:55:27 PM »
I have been running Mach 3 for a while now and just had to switch computers and now I have a problem. I have a M30 comand at the end of a program and when I load it in Mach3 you do not see it and it does not rewind the program. Any ideas? Thanks
Re: Code file
« Reply #1 on: September 19, 2008, 03:57:03 PM »
You need to have a return after he last line in your code or it will not be seen. It is good practice to put a % after the last line of code as that insures you have moved onto the next line :)
Re: Code file
« Reply #2 on: September 19, 2008, 04:03:19 PM »
Thanks for the quick reply. Problem solved.
