May 28, 2012, 01:53:39 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  PoKeys (Moderator: NeoTO)
| | |-+  PoKeys Plug-in
Pages: « 1 2 3 4 5 6   Go Down
Print
Author Topic: PoKeys Plug-in  (Read 12283 times)
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #50 on: September 15, 2008, 12:02:36 PM »
No news  yet Sad
borisz
Active Member
Offline Offline
View Profile WWW
« Reply #51 on: October 06, 2008, 12:27:55 PM »
Hi!
It should be in a week or two.
Please be patient. We want to deliver bug free version.
regards
Boris
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
tnsmachines
Active Member
Offline Offline
View Profile
« Reply #52 on: November 03, 2008, 08:48:43 AM »
Hey guys, just wondering how close the plugin is to having the analog/mpg inputs functioning properly?  Any news? The plugin I have has the inputs working but they have a bit of a delay.  Thanks!
Active Member
Offline Offline
View Profile
« Reply #53 on: November 04, 2008, 11:37:58 AM »
No news yet as far as I know, hopefully soon.
Overloaded
Global Moderator
Offline Offline
View Profile
« Reply #54 on: November 07, 2008, 11:08:27 AM »
From the "Other " forum.
"Hi Guys:
The reports fromthe latest PoKeys update showed a slow responce bogging down
Mach3.
A new plugin has been uploaded to my files section on Yahoo.
The problem is due to the PoKeys sending a large poacket of information whcih
contains all
inputs and encoders. This takes time to get once requested and the previous
plugin was waiting
after the request until it got the responce. This was taking to long, so this
version incorporates a
high speed threaded timer that works at 100hz, its only job is to look to see if
a packet is waiting, and if so translate it, if not ..exit from the routine. In
this way packet waits are eliminated and mach3 doesnt bog down. It simply
request a new packet at 10hz, and the 100hz timer finds the
responce when it comes.
I uploaded the new test a few minutes ago..
Art"
"I haven't failed. I've just found 10,000 ways that won't work."         Edison
"You cannot help men permanently by doing for them what they could and should do for themselves."
Abe Lincoln
Active Member
Offline Offline
View Profile
« Reply #55 on: November 09, 2008, 07:47:43 AM »
I have just tried the latest plugin and although I dont seem to get the hangup when starting Mach now that I sometimes got before, I still have a delay when using the MPG. If I turn the MPG the DRO in Mach doesn't respond until around 1 second later.
 Anyone else confirm this?
Pages: « 1 2 3 4 5 6   Go Up
Print
Jump to:
