Hello Guest it is June 08, 2026, 09:28:17 PM
Author Topic: I am trying Mach3 and lazycam and having problems with curves  (Read 15846 times)
Offline oskie
  •  29 29
Hello,  I am curretnly using DESKNC and everything is working fine.  The file I have attached is no problem for that software.  I was wanting to try to go to Mach 3 because of the flexible setup, but am having difficulty with the items I cut out.  Lazycam seems to want to cut the arc into pieces instead of recognizing it as a single curve.  I used proile flab to generate the dxf and all the lead-ins.  Thanks Oskie
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: I am trying Mach3 and lazycam and having problems with curves
« Reply #1 on: July 03, 2008, 08:59:53 PM »
Hi, Oskie
The pink lines are Arc's, Hears a G-code file of it. .125 cut depth.
Post your G-code file.
Thanks, Chip
Offline oskie
  •  29 29
« Reply #2 on: July 03, 2008, 10:40:35 PM »
I really would like to know how you did that, this is what I get
Offline Chip
  •  2,055 2,055
« Reply #3 on: July 04, 2008, 12:20:43 PM »
Hi, Oskie
Your file has Arcs also, It's mostly that you haven't setup your Cut and Tool table settings.
Load your DXF, Clean, Optimize, Button's (Right Side).
Set "Cut", Info.Set, Rapid Hight, Cut Start, Cut Depth (Don't forget the Neg."-"), Set Layer, Set All Layers, Buttons.
Set "Tool", You'll need to Create and Update some Tools (This will give you your Feeds, Speeds and Cuts Per Pass Info.)
Give it a Try, Chip
Offline oskie
  •  29 29
« Reply #4 on: July 08, 2008, 10:23:28 PM »
I did what I think you said, trying to copy your JPEG, but I am not getting the proper path that you are.  I have posted again what I have after attempting to replicate your fine work.  Thanks
Offline Chip
  •  2,055 2,055
« Reply #5 on: July 08, 2008, 11:16:57 PM »
Hi, Oskie
Check the "Setup" page Options, Your's may be set different.
I reloaded your dxf and just posted the code with no changes and got this below (last pic.).
Thanks, Chip
Offline oskie
  •  29 29
« Reply #6 on: July 09, 2008, 09:28:08 PM »
I am really not getting your results, I have made my screens look like yours and am not getting anthing as good as you are getting.  It seems like my tap file isn't recogonizing when a continuous line is present so it chops up the line into a lot of smaller lines and then rapids back and forth from these tiny line segments.  Is there a file that has you setup file that I can install similar to MACH3 XML file
« Last Edit: July 09, 2008, 09:30:52 PM by oskie »
Offline Chip
  •  2,055 2,055
« Reply #7 on: July 09, 2008, 10:36:55 PM »
Hi, Oskie
Try this LCam xml, Make a copy of yours and delete your LazyCam xml, Rename this one and give it a try.
Thanks, Chip
« Last Edit: July 09, 2008, 10:38:33 PM by Chip »
