Hello
Guest
it is
June 11, 2026, 11:32:24 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
ook hollanders hier? die verstand van Mach2/3/4 enz hebben?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: ook hollanders hier? die verstand van Mach2/3/4 enz hebben? (Read 13650 times)
swets
52
www.arjan-swets.com
on:
May 22, 2006, 04:22:08 PM »
Ik zoek dus mensen die verstand hebben van Mach2/3/4
en met namen hoe je nu iets maakt op maat enzo?
www.arjan-swets.com
ynneb
Re: ook hollanders hier? die verstand van Mach2/3/4 enz hebben?
Reply #1 on:
May 22, 2006, 05:45:47 PM »
Come on Brian, where is your support now
Sorry Swets, I dodnt know if we will be able to help you.
swets
52
www.arjan-swets.com
Reply #2 on:
May 23, 2006, 02:39:43 AM »
Alright I try it in english...
is there a tutorial about import a DXF ...
if i make a circle from 20 mm in autocad,... how to import this in MACH2/3 so that the circle from the cnc machine 20 mm too?
sorry for the bad english.... i do my best....
www.arjan-swets.com
Brian Barker
3,860
Reply #3 on:
May 23, 2006, 08:20:25 AM »
You can do it with Lcam but you are going to have to use COMP to get the Dia to the right size. I have to make a video after the bug fixes that I am working on.
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
