Hello Guest it is June 10, 2026, 06:02:53 PM
Author Topic: Screenset for my touch screen  (Read 266059 times)
Re: Screenset for my touch screen
« Reply #50 on: September 18, 2008, 08:55:47 AM »
I use MPG's all the time and never jog via keyboard or screen but if you press the Tab key on your keyboard you will have the flyout for Jogging. You could set up a button on screen for doing that if you liked, there should be an OEM code for it but at the moment I cant remember it.
 If you want to modify the screen open it with screen 4 and just add another page and use the Jog buttons from the flyout (page 50 I think)
« Reply #51 on: September 18, 2008, 09:06:27 AM »
thanks for the quick silver response.
i'll do that for carbon screen.
at the same time,are u still working on 3-axis-simple screen.as there are still some bugs.(jog is a big issue).rest is worked for me.
i'll bve waiting for the final release of that screen.
Regards
« Reply #52 on: September 18, 2008, 09:11:58 AM »
3axis simple screen is not mine, think that was Jason (Zealous) that did that.
« Reply #53 on: September 18, 2008, 09:14:26 AM »
oops my mistake.
« Reply #54 on: March 20, 2009, 09:19:43 AM »
Been a few years since I have done anything with Mach3. I know this is a very old thread. I am hoping someone out there has a touch screen set for lathe. I have just about finally finished my 3 axis lathe and have a pc case I made with a 1024 x 768 7" touch screen in the front of it. I would like to use a  screen set for it.
Donny
Offline ERP
  •  35 35
« Reply #55 on: June 29, 2011, 01:07:02 PM »
I know this thread is old, but I was trying to get this screen set working with the current version of Mach, and when I load it what I get is compressed in Y to maybe 32 pixels.
Is there some trick with the install I'm missing or is it just not working with the current version on Mach 3?
« Reply #56 on: June 29, 2011, 01:14:10 PM »
I made this screenset with one of the first versions of screen 4 and there was a problem, it applied a background image to one of the pages that was huge and I could not get rid of it.
If you turn off AutoScreen Enlarge (General Config page) then it should view properly, you will either have to restart Mach or reload the screen after you change that setting.
Offline Rimmel
  •  284 284
« Reply #57 on: December 11, 2013, 11:53:11 AM »
Out of interest, when using a touch screen do you still use a standard keyboard for data input or have you found a popup on screen keyboard e.g. like an Ipad keyboard?
thanks
« Reply #58 on: June 22, 2017, 03:03:33 PM »
I have been looking around forum for a bit now and wondered if the guy called hood is on YouTube. Kinda like seeing the stuff he creates.
Thank you
« Reply #59 on: June 22, 2017, 03:05:02 PM »
Also looking forward to trying this touch screen layout tonight
