Hello Guest it is June 11, 2026, 11:32:53 AM
Author Topic: How do I swap the cursor keys for x and y axis?  (Read 13747 times)
Offline Bobo
  •  41 41
    • Haus Metalworks
« on: May 19, 2006, 09:14:10 AM »
When I push the right cursor key the y axis move in the positive direction. I must have messed up something in my profile. My machine is mirroring everything.
Thx for any help.
Re: How do I swap the cursor keys for x and y axis?
« Reply #1 on: May 19, 2006, 04:01:19 PM »
If you go to the config menu then down to system hotkeys you can then click on the x++ and then press the key you want to use, same for the rest of the axis.
« Reply #2 on: May 19, 2006, 10:53:23 PM »
Check to be sure that you don't have your axis set to run in the reverse direction of what it should be...
Thank you
Brian
www.newfangledsolutions.com
www.machsupport.com
Offline Bobo
  •  41 41
    • Haus Metalworks
« Reply #3 on: May 22, 2006, 01:28:01 PM »
That was easy!!!
Thanks Guys.
