Hello Guest it is June 11, 2026, 07:00:37 PM
Author Topic: Grex + printer port for MPG  (Read 9677 times)
« on: May 27, 2008, 05:12:50 AM »
Firstly,
thanks all for the previous help. I'm just getting back to the machine for the trials.
My question is I am using a Grex and have myself a remote MPG pendant from CNC4PC.
On the config side. I wish to plug the MPG pendant into the printer port and use Mach via ethernet. I'm just trying to get my head around the ports/pins settings to use both via different ports.  Any advice
Jason
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
Re: Grex + printer port for MPG
« Reply #1 on: May 28, 2008, 12:34:41 PM »
I only came across Grex in a post last week, so I am a complete newbie on this.
 All the Grex inputs/outputs are pre determined, so as far as I can see, it must be down to the ports settings.
I would set up the printer port (LPT1) as port 2 on your system, and make sure that in Port/Pins etc, you define which port you want that function on. The pin settings should be as normally allocated.
I do not know whether you can perate the printer port togeyjer with the ethernet connection.
