May 28, 2012, 01:13:57 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  VB and the development of wizards
| | |-+  How does the system wait for spindle reach full speed.
Pages: 1   Go Down
Print
Author Topic: How does the system wait for spindle reach full speed.  (Read 1291 times)
rceebuilder
Active Member
Offline Offline
View Profile
« on: March 26, 2008, 08:33:31 PM »
My spindle  needs some time to reach full speed  So the axis movements should  wait for a while. How can I  do it by a macro?
Rceebuilder
vmax549
Guest
« Reply #1 on: March 26, 2008, 09:07:17 PM »
you could do it by macro but you moght want to try the spindle delay settings you can set spinup and down cw and ccw. Or just set a g4pXX setting after the m3 and before the next g movement.
Bodini
Active Member
Offline Offline
View Profile
« Reply #2 on: March 26, 2008, 11:18:29 PM »
It's built in.  Mach>config>ports and pins>spindle setup (tab)>general parameters section.
Pages: 1   Go Up
Print
Jump to:
