Hello Guest it is June 12, 2026, 10:33:22 PM
Author Topic: Z axis Jogging when MACH is running :)  (Read 8509 times)
« on: December 05, 2007, 01:32:14 PM »
Hi guys,
How can I Jog the Z axis movement when the MACH3 is running?
Example: I will install an inductive sensor in front of the Z axis (laser), When MACH3 is running and when the sensor reads a signal ON the Z axis should move upwards until the sensor signal is OFF(0) otherwise MACH3  should continue running.
Any help will be appreciated
Thank you
carlo
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: Z axis Jogging when MACH is running :)
« Reply #1 on: December 06, 2007, 10:55:37 AM »
Hi Carlo - not exactly sure what it is you're wanting but it puts me in mind of THC in plasma - any use?
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
« Reply #2 on: December 06, 2007, 11:26:43 AM »
The way to do this is with a Macro or a Brain. I haven't done much with Brains so I can't help with that.
If your laser is connected to one of the inputs to Mach3, then you can write a Macro to move the Z axis to wherever you want. Have a look at the tutorial on Scripting and it will give you the idea. Adapt it to what you want to do.
« Reply #3 on: December 08, 2007, 02:40:16 PM »
Hi guys,
Thank you for your reply, I got it.  :o
