Hello Guest it is June 12, 2026, 08:49:22 PM
Author Topic: Mach-3 and L-cam for the lathe  (Read 11894 times)
« on: September 18, 2007, 12:11:13 PM »
Hi Brian and Art
 I haven't checked back for a few month's and was wondering if you guy's got around to working on the lathe part of the program yet.
Rg's
Dennis
Re: Mach-3 and L-cam for the lathe
« Reply #1 on: September 18, 2007, 09:13:22 PM »
Not at this time but I do think the time will be soon... Art has been talking about it .
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: September 19, 2007, 09:38:50 AM »
OK Brian
 Still waiting patiently.
Dennis
« Reply #3 on: September 19, 2007, 08:35:45 PM »
Okay.. we will try not to push you to long... there is so much that we need to do at this time :( The Video Plugin that I did was for fun and not much more then that! I have been working on code that was no fun and I needed a to to play with :)
Looking forward to getting lathe done
Brian
www.machsupport.com
Offline DAlgie
  •  314 314
    • Algie Composite Aircraft
« Reply #4 on: September 19, 2007, 09:53:49 PM »
Sounds good Brian, thank you for this. Just wondering, will the Lcam for lathe replace the wizards already there, or will it be a DXF input type addition to the wizards? As I have never used Lcam, is it integral with Mach, or a stand alone program?
             Dave A.
« Reply #5 on: September 20, 2007, 10:04:56 AM »
Thanks Brain
 I orignaly purchased Mach for the lathe application but also understand that thing's happen and it always take's longer then you expect.
Dennis
« Reply #6 on: September 20, 2007, 09:44:49 PM »
Lcam is what will be used to make a DXF into a lathe program...
I hope the work slows down and I can get back at Lcam hard! I would like to have it doen for the most part... I have about 2 weeks work to finishe what I need to work on in Lcam.
www.machsupport.com
