Hello Guest it is June 10, 2026, 12:03:04 PM
Author Topic: A Lagging axis  (Read 12281 times)
A Lagging axis
« on: July 01, 2007, 08:23:47 PM »
I have a stepper mill with Mach 3, and I have noticed that when moving the z axis up at near top speed, the control seems to start the next move with an x or y motion before the z movement is finished. Does this mean I have my accell decel to slow, or feedrate too high, can I set a permanent dwell between blocks so they finish before the next one starts?
Re: A Lagging axis
« Reply #1 on: July 01, 2007, 10:30:45 PM »
I'm seeing this as well. I will try to find out something for you if no one answers soon.
Re: A Lagging axis
« Reply #2 on: July 02, 2007, 05:56:40 PM »
I had a reply pn CNC zone that told me to switch frrom Constant Velocity Mode to exact stop mode, ...you can find this setting on the config/state menu...I will test it tonight
Re: A Lagging axis
« Reply #3 on: July 02, 2007, 06:03:34 PM »
Yup, that seems to help with that.
Re: A Lagging axis
« Reply #4 on: July 02, 2007, 06:05:26 PM »
I also meant to say, if you have an G64s in your code (CV) replace them with G61 (ES).
Bret
