Hello Guest it is June 12, 2026, 08:41:06 AM
Author Topic: setting up Mach3 lathe  (Read 8279 times)
drdjr
« on: May 19, 2007, 02:16:48 PM »
I am trying to set up a cnc lathe with Mach3 turn. I used bobcad to do a simple taper.
I set the taper at .015 per pass but the machine tries cut the taper depth in a single pass.
can anyone tell me what I am doing wrong
DRDJR
Re: setting up Mach3 lathe
« Reply #1 on: May 19, 2007, 10:16:07 PM »
It sounds like you are not getting the roughing code from BobCad... I don't know how to run BobCad at this point but others on the board should be able to help you.
Brian
www.newfangledsolutions.com
www.machsupport.com
Offline DAlgie
  •  314 314
    • Algie Composite Aircraft
« Reply #2 on: May 23, 2007, 06:30:34 PM »
If it's something simple like a tapered part, then you should try the turn wizards. You can also use a couple of them and cut and paste the code out to make a combined part. You can also get Mach3 to write code to a DXF, however it won't rough it out, only the finish profile will be coded, which isn't much good unfortunately. This is where you will need Bobcad to post code.
