Hello Guest it is June 12, 2026, 07:27:43 PM
Author Topic: MAXPATH42 and Mach2  (Read 17979 times)
catheic
MAXPATH42 and Mach2
« on: March 06, 2006, 10:43:15 PM »
Hello Everyone....
I am a newbie. Please help...
We have a maxpath 42 and i am using mach 2 software. right now, when i open mach2 using the maxpath profile the reset button keeps blinking even if i press it. it says EMERGENCY MODE ACTIVE.
MAXPATH42 is hooked up on a pc with XP OS.
is there anyone here, who has working maxpath42 run by MACH2? please help me with the configuration to make our CNC machine work.
thanks great and i will be waiting for any help.
Cheers to you all
Cathei
« Last Edit: March 06, 2006, 10:44:49 PM by catheic »
Re: MAXPATH42 and Mach2
« Reply #1 on: March 07, 2006, 05:52:07 AM »
There is a good vdeo that Art did on setting up a Mach3 (I would run 3 if I were  you) You can find the video's on the mach support page.
The Video will show you how to fix the Estop problem and if you need more please feel free to ask.
www.newfangledsolutions.com
www.machsupport.com
catheic
« Reply #2 on: March 08, 2006, 07:55:54 PM »
Thank you Brian!
i got the Estop fixed.... great!
anyway, why should i run mach3 instead of 2? is it more easier to configure?
Thanks for the help once again...
Cathei
« Reply #3 on: March 09, 2006, 07:04:10 PM »
The Support for 3 is MUCH better and it will do MANY more things :) (I don't have 2 installed now :) )
www.machsupport.com
catheic
« Reply #4 on: March 09, 2006, 11:55:15 PM »
and works well for your CNC? what CNC machine are you using? ok i will try to install MACH3 and ask Mitchell of MAXNC and will hear what he will say about MACH3... and if he could help me with the pin and emulation setup.
right now my machine is not responding. just powers up and nothing
thank you so much tho for your idea. Great day to you...
« Reply #5 on: March 10, 2006, 06:53:36 AM »
I am running a BP series 1 and 2 , Plasma and a lathe soon :)
IF you would like a hand gettting Mach3 running please send me your XML from mach2 and I will set up one for Mach3
thanks
Brian
www.machsupport.com
catheic
« Reply #6 on: March 12, 2006, 07:04:24 AM »
wow great thanks for your help.. yes will send you the xml file.
i have my machine responded ( i have figured that my parallel port is not working- of the pc where i hooked the CNC)  i have used the cnc software that MAXPATH provided, it worked. however it is not working yet with mach2. i will still talk to MItchell and see how woud help me figure things out.
thanks. i will send you the xml file and i think it's smarter to use 3.
Great weekend to you!
Cathei
