Hello Guest it is June 11, 2026, 08:00:15 AM
Author Topic: Machine configuration file  (Read 8020 times)
« on: April 12, 2007, 02:26:53 PM »
If you want to move a machine to another computer, is there a file that has the machine definition that needs to be copied, or do you have to set it up all over again?
Re: Machine configuration file
« Reply #1 on: April 12, 2007, 03:03:34 PM »
you need to move over you XML file. Most use the Mach3Mill.xml
thanks
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: April 12, 2007, 05:17:24 PM »
Also make sure you copy your Mach1Lic.dat and if you use keygrabber or have a custom screen or custom macros you will need to save them.
