Hello Guest it is June 12, 2026, 01:12:26 AM
Author Topic: Mach control pendant switches  (Read 7768 times)
« on: March 28, 2007, 02:11:51 PM »
What type of switches do I need to do things like turn on coolant, switch axes for my mpg, and turn on/off other things in Mach? Can I use momentary switches or do I have to use continuous/toggle switches?
PS- my setup is G100 & Mach 3
Re: Mach control pendant switches
« Reply #1 on: March 28, 2007, 03:05:21 PM »
Depends how you are interfacing them with the computer, I dont know about the G100 so cant say on that but if you have a keyboard emulator then momentary switches is what you want, if you are using pins on a port then toggle I would think.
