May 28, 2012, 12:45:40 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach3 under Vista
| | |-+  Mach 2 in Vista?
Pages: 1   Go Down
Print
Author Topic: Mach 2 in Vista?  (Read 3219 times)
mike542
Active Member
Offline Offline
View Profile
« on: March 11, 2007, 08:52:53 PM »
I am using Mach 2 on XP Pro to run a home built CNC machine, but I would like to switch to Vista Home Basic Is this possible to do. Any help would be appreciated.
Guest
« Reply #1 on: March 12, 2007, 01:09:37 AM »
why not also switch to Mach3, you will be so much happier Wink
Try it now before you go to Vista, just download and install Mach3 and see the difference. You can have Mach2 and 3 on the same computer, only thing is you can't run both at the same time.
Pages: 1   Go Up
Print
Jump to:
