Hello Guest it is June 10, 2026, 09:13:44 AM
Author Topic: recomend a relay?  (Read 9997 times)
recomend a relay?
« on: February 12, 2007, 08:05:21 AM »
got my mill up and running but I have yet to instal relays on the flood coolant and spindle on off.
was wondering if any one could recommend some relays that would work and maybe a simple drawing the best way to wire them. new to this so Im not even sure where to begin so I want to keep it simple.
Re: recomend a relay?
« Reply #1 on: February 12, 2007, 02:08:52 PM »
I like to use Zero crossing SSR's. they are about 14.00 each and will take the full load of the pump (up to 10-20 amps)
I go the last one from MSC (I had to make the order for some other stuff at the same time)
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: February 12, 2007, 03:24:10 PM »
can you post me a link.
what about for the mill itself. do i need a different one to handle the 220V ?
and like I said Ive never done this before so any tips ???
« Reply #3 on: February 13, 2007, 07:27:30 AM »
would this one work?
http://www.allelectronics.com/cgi-bin/item/SRLY-18/500/18_AMP_SOLID-STATE_RELAY,_3-15VDC_CONTROL_.html
how exactly would I wire it. it sais up to 240vac. but it looks to only have terminals for in 2 pairs of wires( Im guessing control and power)?
thanks
