Hello Guest it is June 12, 2026, 09:43:08 AM
Author Topic: Probe function with NCpod  (Read 28391 times)
Offline rcrabb
  •  146 146
« on: January 20, 2007, 08:26:13 PM »
Is the probe function working with the NCpod? I haven't been able to do any probing with the pod. Any information???
Ryan
Re: Probe function with NCpod
« Reply #1 on: January 23, 2007, 06:56:59 AM »
It is nto working at this point... but it will at some point :)
www.newfangledsolutions.com
www.machsupport.com
Offline kookaburra
  •  56 56
  • Fussy? Yep! That's Me ;)
    • Akela Website
« Reply #2 on: January 26, 2007, 05:13:01 PM »
The probing function is being worked on at the moment. There is probing in the pod at the moment but there is no ramping set with it so all probing will be either slow or inaccurate. As soon as the firmware is updated to allow Art to use a ramping facility in the firmware, it will be finised off and activated.
80% there.
Regards
"A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
"If you think you are under pressure - Try opening a sippy cup on an airoplane - 30,000ft in the air"
Greetings From Down Under
Dave Drain
Akela Noble Technologies Pty. Ltd.
« Reply #3 on: August 18, 2008, 01:50:14 PM »
I  have installed my zero plate on the Ncpod + mach3, but it doesn't work.
is this only with my setup, or is this a firmware bug ?
Offline Greolt
  •  956 956
« Reply #4 on: August 18, 2008, 06:18:02 PM »
I honestly don't know if the NCpod is still being developed or dead in the water.  :(
The probing as far as my experience goes does not work.
G31 move will head off in whatever direction it feels like at the time.  No rhyme or reason that I can find.
So unfortunately it is on the shelf. Replaced by the excellent SmoothStepper.
Greg
