Hello Guest it is June 11, 2026, 09:15:50 AM
Author Topic: Unsure relays/mach2/3  (Read 29944 times)
Offline Bear
  •  15 15
« on: January 19, 2007, 04:26:08 PM »
Hi all,
am wondering why my machine blows "main" fuses if main power is turned "on" before computer is "on" or for that matter "off".
if i start computer (XP) and then energize Power&BOB things are fine . If I turn computer off first (shutdown Mach ) then
I loose 2 of 3 fuses. ? is I think I have the motor (3ph440) hooked to the relay outputs (M3 to one relay & M4 to another
and works fine ) and maybe I should change the "Hi" to" Low" ?
 Bear
Re: Unsure relays/mach2/3
« Reply #1 on: January 29, 2007, 07:09:29 AM »
Could you please tell us more about what you have for hardware? Also if you post this in the mach3 forum I think you will get more help :)
www.newfangledsolutions.com
www.machsupport.com
