Hello Guest it is June 11, 2026, 07:46:24 AM
Author Topic: problem with screen4  (Read 11210 times)
Offline faby
  •  74 74
« on: January 18, 2007, 04:45:06 AM »
I have a problem with screen 4
I installed in mach3's folder as request and when I try to open a screenset (.set or .lset) for modify it, appear the dialog shown in the picture...
What it means?
ynneb
Re: problem with screen4
« Reply #1 on: January 18, 2007, 04:53:28 AM »
I dont know what it means, but you could try this program out instead
 http://www.machsupport.com/forum/index.php?topic=2206.msg13102#msg13102
Offline Scott
  •  140 140
« Reply #2 on: January 18, 2007, 08:47:07 AM »
I think that you have to go to "Defaults" up on the menu and tell it where the Mach folder is located.
Scott
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #3 on: January 18, 2007, 09:01:29 AM »
If it's still doesn't work after changing the location you can manual enter the path as well by opening the XML in note pad and write the full director path.
« Reply #4 on: August 28, 2007, 06:27:22 AM »
this is a problem whit your screen resolution
when asked for resolution pop up menu try "custom" an put your actual screen resolution on it.
bye Josep
