Hello Guest it is June 12, 2026, 05:27:29 AM
Author Topic: Mach 3 problem  (Read 18487 times)
manine
Mach 3 problem
« on: February 05, 2006, 12:41:48 AM »
I am new and dumb.
I just loaded Mach 3, and set it up just like Mach2(ports and pins etc.) I started to jog y, it hit the end of travel, tripping it's limit switch. I can't reset it! I manually pulled y out so the switch is de-activated, still the e-stop flashes. If I leave it for a while and click reset, it will not flash for a couple seconds then it starts flashing, with a message that says "limit switch triggered". When I close Mach3 and open Mach2 I have no problem, which tells me it's not the switch.
Please help, I am excited about trying Mach3... but this is very frustrating!
-Matt
Re: Mach 3 problem
« Reply #1 on: February 05, 2006, 06:23:50 AM »
On the settings page there is a button to OVER RIDE LIMITS. press this button, reset the control and jog off the limit.
That should do it:)
www.newfangledsolutions.com
www.machsupport.com
Art
Re: Mach 3 problem
« Reply #2 on: February 05, 2006, 08:21:42 AM »
Matt:
 Make sure the LED is off for that home switch on the Diags pahe. If not, reverse its low active setting. Does it still trigger every few seconds?
Art
manine
Re: Mach 3 problem
« Reply #3 on: February 05, 2006, 10:06:58 AM »
The home LED is off...
And I can't over ride limits, the button won't turn on...
And now a new problem, the CNC powered down on me, now when I plug it in it powers up for a fraction of a second, then off. This just happened, I had no problems (power) last night.
I can reset though!
AAAARRRRGGHH
-Matt
Offline scottybev
  •  23 23
  • A nice batch of archtops
Re: Mach 3 problem
« Reply #4 on: February 06, 2006, 09:52:59 PM »
You are not dumb and there are no dumb questions.
I am new and dumb.
-Matt
Much appreciated
Scotty
Re: Mach 3 problem
« Reply #5 on: February 07, 2006, 04:20:09 AM »
So Matt how are you doing now?? Did you get your power problem fixed?
www.machsupport.com
